[SOLVED] Indiemicro IND83209
  • [SOLVED] Indiemicro IND83209
    Good Day.
    We try to program this part IND83209 32-bit Arm® Cortex® M0 processor from
    indiemicro,
    Is possible to program using SEGGER hardware ?
    Indie Semiconductor
    indiemicro.com/products/automotive/ind83209
    We contact PCB development team about device they use they comment use
    Segger JLink debugger for development.
    mouser.com/ProductDetail/Segge…tknfhE%2FmkLhf91DHA%3D%3D
    For initial production samples we like try this Flasher Portable/Flasher Portable PLUS.
    I search on the list device support not found.
    Thank you for support.
    Jorge.
    There is no official support from SEGGER at this point but you can add support on your own:
    wiki.segger.com/Open_Flashloader
    There may also be an open flash loader implementation from Indiemicro at this point, we simply do not know,
    as they could do an open flash loader on their own as well.
    It might be worth checking with them.
