[SOLVED] Unable to connect to target using JLink Edu Mini
  • [SOLVED] Unable to connect to target using JLink Edu Mini
    couple of weeks ago I bought JLink Edu Mini for hobby projects. Since then I am unable to debug or flash using it.
    I have tried to debug and flash RPi Pico and STM32F429ZI discovery board.
    For Pi Pico it only showed messages about ConfigTargetSettings() and never got connected.
    For STM32F429, with SWD interface on STM32CubeIDE I got following messages on console:
    Connecting to J-Link...
    J-Link is connected.
    Firmware: J-Link EDU Mini V1 compiled Aug 10 2021 11:19:22
    Hardware: V1.00
    S/N: XXXXXXXXXX
    Feature(s): FlashBP, GDB
    Checking target voltage...
    Target voltage: 2.96 V
    Listening on TCP/IP port 2331
    Connecting to target...
    ERROR: STM32: Connecting to CPU via connect under reset failed.
    ERROR: Could not connect to target.
    Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
    Shutting down...
    Please check power, connection and settings.
    All the pin connections are done according to Segger application nore "Connecting J-Link to STM32-Discovery eval boards".
    I also tried to connect using JLink command line utility (both on Windows and Linux) but it did not help.
    Could you please suggest a solution or give some hints?
    Thanks in advance.
    Abhijeet
  • Pretty sure that it is a setup issue.
    If you check the forum and internet, you will find quite some EDU mini users that are using the Pico boards and STM32 derivatives successfuly.
    Possible problem sources:
    Broken wires
    Swapped signals (wrong wiring)
    Half-way soldered connectors
    Can you please send the output of J-Link Commander (command line utility) for both,
    the Pico and the STM32?
    thank you for response and info.
    I rechecked the connections but I still get following messages. I see that board is reset for a second but does not get connected. Is my JLink broken? I am using v7.52c of JLink Commander.
    J) JTAG (Default)
    S) SWD
    T) cJTAG
    TIF>S
    Speed>
    Device "STM32F429ZI" selected.
    Connecting to target via SWD
    InitTarget() start
    Can not attach to CPU. Trying connect under reset.
    InitTarget() end
    InitTarget() start
    InitTarget() end
    InitTarget() start
    InitTarget() end
    InitTarget() start
    InitTarget() end
    Cannot connect to target.
    Thanks & Regards,
    Abhijeet
    I could connect to RPi Pico over SWD using JLink Edu Mini and also erase and flash it. Also debugging a program in Segger Embedded Studio worked. The problem was actually with loose connecting wires. Thanks for your suggestion regarding bad connections.
    In similar way, I shall also be able to connect with STM32.
    I am happy that my JLink is working. :)
    Thanks & Regards,
    Abhijeet
    PS: Here is the log of JLink Commander. In case if anyone faces similar problem, these are the steps that are executed by JLink to connect with RPi Pico. Due to loose cable connections my JLink had stuck at ConfigTargetSettings in loop. After tightening the cable connections, connection was successfully established.
    J-Link>connect
    Please specify device / core. <Default>: RP2040_M0_0
    Type '?' for selection dialog
    Device>
    J) JTAG (Default)
    S) SWD
    T) cJTAG
    TIF>S
    Speed>
    Device "RP2040_M0_0" selected.
    ConfigTargetSettings() start
    J-Link script: ConfigTargetSettings()
    ConfigTargetSettings() end
    Found SW-DP with ID 0x0BC12477
    DPIDR: 0x0BC12477
    AP[0]: AHB-AP (IDR: 0x04770031)
    AP[0]: Core found
    CPUID register: 0x410CC601. Implementer code: 0x41 (ARM)
    Found Cortex-M0 r0p1, Little endian.
    FPUnit: 4 code (BP) slots and 0 literal slots
    CoreSight components:
    ROMTbl[0] @ E00FF000
    ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB008 SCS
    ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 000BB00A DWT
    ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 000BB00B FPB
    Cortex-M0 identified.
  • Hi Abhijeet,
