[ABANDONED] On nRF51422 and nRF52840: No emulators connected via USB when connected from Windows 10
  • [ABANDONED] On nRF51422 and nRF52840: No emulators connected via USB when connected from Windows 10
    I just recently got both nRF51422 and nRF52844 DK. However, when I tried to connect through J-LINK, the error message popped up: No emulators connected via USB. Do you want to connect through TCP/IP?
    I have checked in Device Manager that J-link has showed up under COM port and USB controllers:
    [img]https://devzone.nordicsemi.com/resized-image/__size/1280x960/__key/communityserver-discussions-components-files/4/pastedimage1614889715457v1.png[/img]
    So far, I have tried many things individually as following to no avail. I tried on two boards and they appear to be working with LE5 blinking.
    1. install the latest Segger embedded studio for x64 and x86 and tried both. The issue persists;
    2. install the latest J-link software pack for windows;
    3. manually update the driver for J-link:
    [img]https://devzone.nordicsemi.com/resized-image/__size/1280x960/__key/communityserver-discussions-components-files/4/pastedimage1614890048446v2.png[/img]
    4. manually select the USB driver under SES:
    [img]https://devzone.nordicsemi.com/resized-image/__size/1280x960/__key/communityserver-discussions-components-files/4/pastedimage1614890344088v3.png[/img]
    5. update to the latest MCU firmware (J-Link OB-SAM3U128-V2-NordicSemi 170724.bin)
    6. switch to a different PC also using windows 10;
    7. switch to a different USB cable;
    8. switch to a different DK;
    9. step 1- 8 individually with rebooting my PC and reopen SES;
    10. tried to connect J-Link through TCP/IP. But I failed to find the correct s/n of J-link;
    11. measure the voltage of pins to make sure the board is good;
    At this moment, I ran out of ideas to try and would appreciate any input. Thanks.
    Your first screenshot shows that the virtual COM port and the MSD (drag & drop programming) part of the OB was enumerated successfully.
    However, there is a 3rd component in the USB descriptor that is the J-Link itself.
    You should see this as well:
    As long as you do not see this, the J-Link component was not enumerated successfully and Embedded Studio etc. cannot communicate with J-Link.
    The "driver updates" you did do not really help anything as you performed them on the virtual COM port part which is not the J-Link part.
    Also, the virtual COM port part is identified fine.
    We see 2 possible reasons for the failure:
    1) Bad setup (which is unlikely as you changed cables, ... and also the PC)
    2) Bad board
    Do you have a 2nd dev kit to check against?
    We do not suspect a generic problem here because:
    There are tens of thousands of these boards out there and if there would be a generic problem with Windows 10, there would be many many support requests like this.
