Issues with Programming my Micro...Could not Transfer JTAG data
  • Issues with Programming my Micro...Could not Transfer JTAG data
    Hi, I am not sure why I am not able to program my STM32F103C8T6 on the board I just designed as part of my internship. I have tried unlocking the flash, putting pull-ups/pull-downs on various JTAG lines, ensured all my VDD/VCC on the chip are hooked up and properly decoupled, and a variety of other ideas. Here is what I get when I open the JLINK command line utility:
    SEGGER J-Link Commander V4.08f ('?' for help)
    Compiled Jul 8 2009 19:55:01
    DLL version V4.08f, compiled Jul 8 2009 19:54:44
    Firmware: J-Link compiled Jul 30 2008 11:24:37 ARM Rev.5
    Hardware: V5.30
    S/N : 10006174
    OEM : IARKS
    VTarget = 3.332V
    Info: TotalIRLen = 9, IRPrint = 0x0011
    Info: Found Cortex-M3 r1p1, Little endian.
    Info: TPIU fitted.
    Info: FPUnit: 6 code (BP) slots and 2 literal slots
    Found 2 JTAG devices, Total IRLen = 9:
    #0 Id: 0x3BA00477, IRLen: 4, IRPrint: 0x1 Cortex-M3 Core
    #1 Id: 0x16410041, IRLen: 5, IRPrint: 0x1 STM32 Boundary Scan
    Cortex-M3 identified.
    JTAG speed: 5 kHz
    This is the log file when I program using the IAR Kickstart stuff:
    Logging started @ 2009-08-10 21:00
    DLL Compiled: Jul 8 2009 19:54:44
    Out of sync , resynchronising... (0003ms, 0000ms total)
    T0FBC 000:000 Firmware: J-Link compiled Jul 30 2008 11:24:37 ARM Rev.5 (0071ms, 0000ms total)
    T0FBC 000:000 returns O.K. (0141ms, 0000ms total)
    T0FBC 000:142 JLINKARM_GetDLLVersion() returns 40806 (0000ms, 0141ms total)
    T0FBC 000:143 JLINKARM_GetCompileDateTime() (0000ms, 0141ms total)
    T0FBC 000:144 JLINKARM_GetFirmwareString(...) (0000ms, 0141ms total)
    T0FBC 000:144 JLINKARM_SelectDeviceFamily(3) (0000ms, 0141ms total)
    T0FBC 000:144 JLINKARM_SetSpeed(1) (0000ms, 0141ms total)
    T0FBC 000:146 JLINKARM_SetResetDelay(0) (0000ms, 0141ms total)
    T0FBC 000:146 JLINKARM_ResetPullsRESET(ON) (0000ms, 0141ms total)
    T0FBC 000:146 JLINKARM_Reset() >0x2F8 JTAG>TotalIRLen = 9, IRPrint = 0x0011 >0x30 JTAG> >0x210 JTAG> >0x38 JTAG> >0xF0 JTAG> >0x80 JTAG> >0x230 JTAG> >0x200 JTAG> >0xE0 JTAG> >0xE0 JTAG>Found Cortex-M3 r1p1, Little endian. >0x80 JTAG> >0x170 JTAG> >0xE0 JTAG> >0xE0 JTAG>TPIU fitted. >0xE0 JTAG> >0xE0 JTAG> FPUnit: 6 code (BP) slots and 2 literal slots >0xE0 JTAG> >0x180 JTAG> >0x170 JTAG> >0x1A0 JTAG> >0xE0 JTAG> >0xE0 JTAG> >0x170 JTAG> >0x170 JTAG> >0xE0 JTAG> >0xE0 JTAG> >0xEF8 JTAG> >0x1A0 JTAG>
    >0xE0 JTAG> >0xEF8 JTAG> >0x110 JTAG> >0xE0 JTAG> (16737ms, 0141ms total)
    T0FBC 016:884 JLINKARM_GetIdData(...) ScanLen=9 NumDevices=2 aId[0]=0x3BA00477 aIrRead[0]=0 aScanLen[0]=0 aScanRead[0]=0 (0001ms, 16878ms total)
    T0FBC 016:886 JLINKARM_JTAG_GetDeviceID(DeviceIndex = 0) returns 0x3BA00477 (0000ms, 16879ms total)
    T0FBC 016:887 JLINKARM_JTAG_GetDeviceInfo(DeviceIndex = 0) returns 0x00 (0000ms, 16879ms total)
    T0FBC 016:887 JLINKARM_JTAG_GetDeviceID(DeviceIndex = 1) returns 0x16410041 (0000ms, 16879ms total)
    T0FBC 016:887 JLINKARM_JTAG_GetDeviceInfo(DeviceIndex = 1) returns 0x00 (0000ms, 16879ms total)
    T0FBC 016:888 JLINKARM_GetDeviceFamily() returns 3 (0000ms, 16879ms total)
    T0FBC 016:888 JLINKARM_Halt() >0xE0 JTAG> returns 0x00 (0228ms, 16879ms total)
    JLINKARM_AddMirrorAreaEx(Addr = 0x00000000, Size = 0x00000000) (0000ms, 0000ms total)
    JLINKARM_IsHalted() >0x2F8 JTAG>TotalIRLen = 9, IRPrint = 0x0011 >0x30 JTAG> >0x210 JTAG> >0x38 JTAG> >0xF0 JTAG> >0x80 JTAG> >0x230 JTAG> >0x200 JTAG> >0xE0 JTAG> >0xE0 JTAG>Found Cortex-M3 r1p1, Little endian. >0x80 JTAG> >0x170 JTAG> >0xE0 JTAG> >0xE0 JTAG>TPIU fitted. >0xE0 JTAG> >0xE0 JTAG> FPUnit: 6 code (BP) slots and 2 literal slots >0xE0 JTAG> >0xF0 JTAG> returns TRUE (5203ms, 17108ms total)
    T0FBC 022:323 JLINKARM_ReadMemU32(0xE0042000, 0x0001 Items, ...) >0x170 JTAG> -- Data: 10 64 03 20 returns 0x01 (0375ms, 17108ms total)
    T0FBC 022:699 JLINKARM_GetEmuCaps() returns 0x80D7BBF (0000ms, 17483ms total)
    T0FBC 022:700 JLINKARM_GetSpeed() returns 0x01 (0000ms, 17483ms total)
    T0FBC 022:703 JLINKARM_BeginDownload(Flags = 0x03) (0000ms, 17483ms total)
    T0FBC 022:729 JLINKARM_WriteMem(0x00000000, 0x0134 Bytes, ...) -- Data: 00 04 00 20 F5 00 00 00 35 01 00 00 35 01 00 00 ...
    JLINKARM_ReadMemHW(0x00000000, 0x0004 Bytes, ...) >0x170 JTAG> -- Data: FF FF FF FF returns 0x00 (0361ms, 0000ms total)
    JLINKARM_ReadMemHW(0x08000000, 0x0004 Bytes, ...) >0x170 JTAG> -- Data: FF FF FF FF returns 0x00 (0374ms, 0361ms total)
    JLINKARM_WriteMemHW(0x00000000, 0x0004 Bytes, ...) -- Data: 00 00 01 00 >0x170 JTAG> returns 0xFFFFFFFF (0375ms, 0735ms total)
    JLINKARM_ReadMemHW(0x00000000, 0x0004 Bytes, ...) >0x170 JTAG> -- Data: FF FF FF FF returns 0x00 (0374ms, 1110ms total)
    -- MA0 is in flash -- Unmirror addr 0x00000000 >0xFB0 JTAG> returns 0x04 (5548ms, 17483ms total)
    T0FBC 028:278 JLINKARM_WriteU16(0x00000134, 0xE7FE) -- Unmirror addr 0x00000134 >0x170 JTAG> returns 0x00 (0375ms, 23031ms total)
    T0FBC 028:659 JLINKARM_EndDownload() (0000ms, 23406ms total)
    T0FBC 028:659 JLINKARM_ReadMemU32(0x00000000, 0x004D Items, ...) -- Unmirror addr 0x00000000 >0x1040 JTAG> -- Updating C cache (320 bytes @ 0x08000000) -- Read from C cache (308 bytes @ 0x08000000) -- Data: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ... returns 0x4D (4209ms, 23406ms total)
    T0FBC 032:869 JLINKARM_ReadMemU16(0x00000134, 0x0001 Items, ...) -- Unmirror addr 0x00000134 -- Read from C cache (2 bytes @ 0x08000134) -- Data: FF FF returns 0x01 (0001ms, 27615ms total)
    T0FBC 034:987 JLINKARM_ReadMemU32(0x00000000, 0x0001 Items, ...) -- Unmirror addr 0x00000000 -- Read from C cache (4 bytes @ 0x08000000) -- Data: FF FF FF FF returns 0x01 (0001ms, 27616ms total)
    T0FBC 034:988 JLINKARM_ReadMemU32(0x00000004, 0x0001 Items, ...) -- Unmirror addr 0x00000004 -- Read from C cache (4 bytes @ 0x08000004) -- Data: FF FF FF FF returns 0x01 (0000ms, 27617ms total)
    T0FBC 037:244 JLINKARM_ResetPullsRESET(OFF) (0000ms, 27617ms total)
    T0FBC 037:244 JLINKARM_Reset() >0x2F8 JTAG>TotalIRLen = 9, IRPrint = 0x0011 >0x30 JTAG> >0x210 JTAG> >0x38 JTAG> >0xF0 JTAG> >0x80 JTAG> >0x230 JTAG> >0x200 JTAG> >0xE0 JTAG> >0xE0 JTAG>Found Cortex-M3 r1p1, Little endian. >0x80 JTAG> >0x170 JTAG> >0xE0 JTAG> >0xE0 JTAG>TPIU fitted. >0xE0 JTAG> >0xE0 JTAG> FPUnit: 6 code (BP) slots and 2 literal slots >0xE0 JTAG> >0x180 JTAG> >0x170 JTAG> >0xE0 JTAG> >0xE0 JTAG> >0x170 JTAG> >0x170 JTAG> >0xE0 JTAG> >0xEF8 JTAG> >0x110 JTAG> >0xE0 JTAG>
    (11547ms, 27617ms total)
    T0FBC 048:792 JLINKARM_ReadReg(R15) returns 0xFFFFFFFE (0001ms, 39164ms total)
    T0FBC 048:793 JLINKARM_ReadReg(MSP) returns 0xFFFFFFFC (0000ms, 39165ms total)
    T0FBC 048:793 JLINKARM_ReadReg(PSP) returns 0xE6FED1A0 (0000ms, 39165ms total)
    T0FBC 048:793 JLINKARM_ReadReg(CFBP) returns 0x00000000 (0000ms, 39165ms total)
    T0FBC 048:793 JLINKARM_IsHalted() >0xE0 JTAG> returns TRUE (0230ms, 39165ms total)
    T0FBC 049:024 JLINKARM_ReadMemU32(0xE000EDFC, 0x0001 Items, ...) >0x170 JTAG> -- Data: 00 00 00 00 returns 0x01 (0374ms, 39165ms total)
    T0FBC 049:398 JLINKARM_WriteMem(0xE000EDFC, 0x0004 Bytes, ...) -- Data: 00 00 00 01 >0x170 JTAG> -- Invalidate MA0 status returns 0x04 (0374ms, 39539ms total)
    T0FBC 049:824 JLINKARM_ReadReg(R15) returns 0xFFFFFFFE (0001ms, 39913ms total)
    T0FBC 049:825 JLINKARM_ReadMemU16(0x00000040, 0x0001 Items, ...)
    JLINKARM_ReadMemHW(0x00000000, 0x0004 Bytes, ...) >0x170 JTAG> -- Data: FF FF FF FF returns 0x00 (0374ms, 0000ms total)
    JLINKARM_ReadMemHW(0x08000000, 0x0004 Bytes, ...) >0x170 JTAG> -- Data: FF FF FF FF returns 0x00 (0374ms, 0374ms total)
    JLINKARM_WriteMemHW(0x00000000, 0x0004 Bytes, ...) -- Data: 00 00 01 00 >0x170 JTAG> returns 0xFFFFFFFF (0374ms, 0748ms total)
    JLINKARM_ReadMemHW(0x00000000, 0x0004 Bytes, ...) >0x170 JTAG> -- Data: FF FF FF FF returns 0x00 (0375ms, 1122ms total)
    -- MA0 is in flash -- Unmirror addr 0x00000040 >0x440 JTAG> -- Updating C cache (64 bytes @ 0x08000040) -- Read from C cache (2 bytes @ 0x08000040) -- Data: FF FF returns 0x01 (2600ms, 39914ms total)
    T0FBC 052:426 JLINKARM_SetBPEx(Addr = 0x00000040, Type = 0xFFFFFFF2) -- Unmirror addr 0x00000040 returns 0x00000001 (0001ms, 42514ms total)
    T0FBC 052:427 JLINKARM_BeginDownload(Flags = 0x01) (0000ms, 42515ms total)
    T0FBC 052:427 JLINKARM_WriteMem(0x20000000, 0x0400 Bytes, ...) -- Data: CD CD CD CD CD CD CD CD CD CD CD CD CD CD CD CD ... >0x3140 JTAG>
    ***** Error: Could not transfer JTAG data. returns 0xFFFFFFFF (5011ms, 42515ms total)
    IAR seems to freeze everytime I try to program the chip.
    Any help would be highly appreciated.
    Thank You,
    A very frustrated EE intern.
    Please feel free to email me at george[dot]melcer[at]liquidr[dot]com
  • Hello AppleIntern00,
    I have checked this with the following testing environment:
    IAR EWARM V5.40a
    J-Link DLL V4.08f
    J-Link HW Version: V5.4
    IAR sample project: arm\examples\ST\STM32F10x\STM32-Eval\STM3210E-EVAL_Demo\Demo\project\EWARMv5
    Eval Board: ST MB672 (STM32F103ZET6)
    And it seems to work fine.
    What seems a little bit confusing in the log you postet, is that line:
    Is it correct that you are working with 1 kHz JTAG speed?
    Communication in general seems to work since JLink.exe is able to identify the core and is able to connect to it.
    If you are using a macro file could you please check if there might be some initialization which could cause problems (wrong PLL init etc.)?
