[SOLVED] Sabre-Lite I.MX6Q signal manipulation
  • [SOLVED] Sabre-Lite I.MX6Q signal manipulation
    Dear sir/madam,
    Before I decide to purchase a Segger J-Link, I would like to make sure it is usable for my particular use-case. In short, I want to manipulate one of the input signals of the Cortex A9 cores inside the I.MX6Q. I have been informed by Freescale that this can be done using JTag, hence my desire for such a device. I do however have a few concerns:
    - Does the Segger J-link and/or software support the challenge/response mechanism for the implemented Secure JTAG implementation?
    - Can I use the Segger software to assert a single pin, or do I need additional tools for this?
    - How does the software understand which input signal is which? Are there some sort of "netlists" provided with the software? Or is this provided through the JTAG controller? Do I need to request these netlists somewhere else?
    - Can I use the Segger J-Link with a 20-pin JTAG to 10-pin microJTAG convertor?
    I hope someone can shed some light on this for me. Many thanks in advance. Yours,
    Roy
  • Hello Roy,
    J-link supports debugging via the standard JTAG interface on the i.MX6.
    As far as I understand, the secure JTAG (SJTAG) is a special unit in the i.XM6 which, if enabled,
    needs to be initialized with a security key to enable the TAP for regular JTAG debugging.
    In general, you can write an application with the J-Link SDK which implements this "authentication" via the SJTAG unit and once this is done,
    you should be able to perform operations via the regular debug interface via J-Link, until the unit is secured again (on reset? power-on reset?).
    Could you please specify what exactly you mean here?
    Of course, J-Link allows access to the peripheral registers of the CPU which of course then also allows toggling on GPIOs etc.
    Otherwise, it would be a pretty useless debug tool...
    Yes, why shouldn't you be able to do so?
    The Sabre Lite Kit provides a 10-pin Cortex-M connector.
    - Alex
  • Is it possible to implement the Secure JTAG authentication using J-Link Software and Documentation Pack commands? without J-Link SDK.
    How could I read TDO line?
    How could I write raw value to TDI? (Is it wjraw command? Can you put an example of use?)
    I'm using J-Link Plus with iMX6 Solo.
    Thanks in advance for your help.
    Joan
  • Hi Joan,
    Yes, this can be done using J-Link script files. Further information regarding J-Link script files can be found in the J-Link user manual (UM08001).
    Can also be done using J-Link script files. We do not have an example for the iMX6S device but there are examples for other devices in the J-Link Software and Documentation Package installation directory, which can be used as reference: %INST_DIR%\Samples\JLink\Scripts
    Erik
