J-Link embedded in a Energy Micro STK-3600 on OSX loses communications whenever new code is flashed
  • J-Link embedded in a Energy Micro STK-3600 on OSX loses communications whenever new code is flashed
    I am using OSX and v4.82 of the J-Link drivers and after each time I flash the target processor (I am using the STK-3600 to debug my own design), almost every time I lose communications and have to disconnect the STK-3600 for a minute or two and then reconnect.
    If I plug the same STK-3700 into a Windows machine, I do not have this issue.
    Here is an example where the code downloads, but the fails to start the CPU:
    1. SEGGER J-Link GDB Server V4.82 Command Line Version
    2. JLinkARM.dll V4.82 (DLL compiled Mar 10 2014 19:13:25)
    3. -----GDB Server start settings-----
    4. GDBInit file: none
    5. GDB Server Listening port: 2331
    6. SWO raw output listening port: 2332
    7. Terminal I/O port: 2333
    8. Accept remote connection: localhost only
    9. Generate logfile: off
    10. Verify download: on
    11. Init regs on start: on
    12. Silent mode: off
    13. Single run mode: on
    14. Target connection timeout: 5 sec.
    15. ------J-Link related settings------
    16. J-Link Host interface: USB
    17. J-Link script: none
    18. J-Link settings file: none
    19. ------Target related settings------
    20. Target device: EFM32LG330F128
    21. Target interface: SWD
    22. Target interface speed: 4kHz
    23. Target endian: little
    24. Connecting to J-Link...
    25. J-Link is connected.
    26. Firmware: Energy Micro EFM32 compiled Nov 6 2012 20:02:43
    27. Hardware: V7.00
    28. S/N: 440004343
    29. Feature(s): GDB
    30. Checking target voltage...
    31. Target voltage: 3.34 V
    32. Listening on TCP/IP port 2331
    33. Connecting to target...Connected to target
    34. Waiting for GDB connection...Connected to 127.0.0.1
    35. Reading all registers
    36. Read 4 bytes @ address 0x00000000 (Data = 0x20008000)
    37. Target interface speed set to 30 kHz
    38. Resetting target
    39. Halting target CPU...
    40. ...Target halted (PC = 0x000000DC)
    41. R0 = 40088000, R1 = 00000000, R2 = 00000010, R3 = 00000000
    42. R4 = 100006FC, R5 = 10000754, R6 = 10000754, R7 = 00000000
    43. R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000
    44. R12= 10000670, R13= 20008000, MSP= 20008000, PSP= 20001B78
    45. R14(LR) = FFFFFFFF, R15(PC) = 000000DC
    46. XPSR 01000000, APSR 00000000, EPSR 01000000, IPSR 00000000
    47. CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00
    48. Reading all registers
    49. Select auto target interface speed (2000 kHz)
    50. Flash breakpoints enabled
    51. Semi-hosting enabled (VectorAddr = 0x08)
    52. Semihosting I/O set to TELNET Client
    53. SWO disabled succesfully.
    54. SWO enabled succesfully.
    55. Downloading 16112 bytes @ address 0x00000000 - Verified OK
    56. Downloading 16176 bytes @ address 0x00003EF0 - Verified OK
    57. Downloading 16176 bytes @ address 0x00007E20 - Verified OK
    58. Downloading 16144 bytes @ address 0x0000BD50 - Verified OK
    59. Downloading 16144 bytes @ address 0x0000FC60 - Verified OK
    60. Downloading 16208 bytes @ address 0x00013B70 - Verified OK
    61. Downloading 4428 bytes @ address 0x00017AC0 - Verified OK
    62. Downloading 4 bytes @ address 0x00018C0C - Verified OK
    63. Downloading 8 bytes @ address 0x00018C10 - Verified OK
    64. Downloading 3776 bytes @ address 0x00018C18 - Verified OK
    65. Downloading 1536 bytes @ address 0x00019AD8 - Verified OK
    66. Read 4 bytes @ address 0x000000DC (Data = 0x47804801)
    67. Read 2 bytes @ address 0x00000122 (Data = 0xE7F6)
    68. Read 2 bytes @ address 0x000000E2 (Data = 0x4700)
    69. Read 2 bytes @ address 0x0000014C (Data = 0xF2C0)
    70. Read 2 bytes @ address 0x0000AB18 (Data = 0xF7FE)
    71. Read 2 bytes @ address 0x0000AB24 (Data = 0xF249)
    72. Read 2 bytes @ address 0x0000AB18 (Data = 0xF7FE)
    73. Read 2 bytes @ address 0x0000AB56 (Data = 0xF00A)
    74. Read 2 bytes @ address 0x0000B7D4 (Data = 0xF44F)
    75. Read 2 bytes @ address 0x0000B8CE (Data = 0xF04F)
    76. Read 2 bytes @ address 0x0000AB18 (Data = 0xF7FE)
    77. Read 2 bytes @ address 0x0000AB18 (Data = 0xF7FE)
    78. Read 2 bytes @ address 0x0000B920 (Data = 0xF640)
    79. Read 2 bytes @ address 0x0000B922 (Data = 0x0381)
    80. Read 2 bytes @ address 0x0000B924 (Data = 0xF2C2)
    81. Read 2 bytes @ address 0x0000B926 (Data = 0x0300)
    82. Read 2 bytes @ address 0x0000B920 (Data = 0xF640)
    83. Read 2 bytes @ address 0x0000AB18 (Data = 0xF7FE)
    84. Read 2 bytes @ address 0x0000AB52 (Data = 0xF7FF)
    85. Read 2 bytes @ address 0x0000B95E (Data = 0xF89D)
    86. Read 2 bytes @ address 0x0000B95E (Data = 0xF89D)
    87. Read 2 bytes @ address 0x0000AB18 (Data = 0xF7FE)
    88. Read 2 bytes @ address 0x0000AB18 (Data = 0xF7FE)
    89. Read 2 bytes @ address 0x0000AB18 (Data = 0xF7FE)
    90. Read 2 bytes @ address 0x0000AB56 (Data = 0xF00A)
    91. Read 2 bytes @ address 0x0000AB18 (Data = 0xF7FE)
    92. Read 2 bytes @ address 0x0000AB20 (Data = 0xF000)
    93. Read 2 bytes @ address 0x000000DC (Data = 0x4801)
    94. Read 4 bytes @ address 0x000000E4 (Data = 0x00000379)
    95. Read 2 bytes @ address 0x000000DE (Data = 0x4780)
    96. Read 2 bytes @ address 0x000000DE (Data = 0x4780)
    97. Read 2 bytes @ address 0x00004D16 (Data = 0x2051)
    98. Read 2 bytes @ address 0x00004D16 (Data = 0x2051)
    99. Read 2 bytes @ address 0x0000AB18 (Data = 0xF7FE)
    100. Read 2 bytes @ address 0x0000ABE6 (Data = 0xF249)
    101. Read 2 bytes @ address 0x0000AB18 (Data = 0xF7FE)
    102. Read 2 bytes @ address 0x0000AB56 (Data = 0xF00A)
    103. Read 2 bytes @ address 0x0000AB18 (Data = 0xF7FE)
    104. Read 2 bytes @ address 0x0000AB52 (Data = 0xF7FF)
    105. Read 2 bytes @ address 0x000099B8 (Data = 0x9B01)
    106. Read 2 bytes @ address 0x000099B8 (Data = 0x9B01)
    107. Read 2 bytes @ address 0x000000F0 (Data = 0x4901)
    108. Read 4 bytes @ address 0x000000F8 (Data = 0x20008000)
    109. Read 2 bytes @ address 0x000000F2 (Data = 0x468D)
    110. Read 2 bytes @ address 0x000000F2 (Data = 0x468D)
    111. Read 2 bytes @ address 0x0000AB18 (Data = 0xF7FE)
    112. Read 2 bytes @ address 0x0000AB18 (Data = 0xF7FE)
    113. Read 2 bytes @ address 0x0000AB18 (Data = 0xF7FE)
    114. Resetting target
    115. Halting target CPU...
    116. ...Target halted (PC = 0x000000DC)
    117. R0 = 40088000, R1 = 00000000, R2 = 00000010, R3 = 00000000
    118. R4 = 100006FC, R5 = 10000754, R6 = 10000754, R7 = 00000000
    119. R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000
    120. R12= 10000670, R13= 20008000, MSP= 20008000, PSP= 20001B78
    121. R14(LR) = FFFFFFFF, R15(PC) = 000000DC
    122. XPSR 01000000, APSR 00000000, EPSR 01000000, IPSR 00000000
    123. CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00
    124. Reading all registers
    125. Read 4 bytes @ address 0x000000DC (Data = 0x47804801)
    126. Setting breakpoint @ address 0x000000DE, Size = 2, BPHandle = 0x0002
    127. Setting breakpoint @ address 0x000099B8, Size = 2, BPHandle = 0x0003
    128. Setting breakpoint @ address 0x0000AB18, Size = 2, BPHandle = 0x0004
    129. Setting breakpoint @ address 0x0000AB56, Size = 2, BPHandle = 0x0005
    130. Setting breakpoint @ address 0x0000ABE6, Size = 2, BPHandle = 0x0006
    131. Starting target CPU...
    132. ERROR: Communication timed out: Requested 24 bytes, received 0 bytes !
    133. Could not start CPU core. (ErrorCode: -1)
    134. ...Target halted (PC = 0x00000000)
    135. Reading all registers
    136. Removing breakpoint @ address 0x000000DE, Size = 2
    137. WARNING: Could not remove breakpoint @ address 0x000000DE
    138. Removing breakpoint @ address 0x000099B8, Size = 2
    139. WARNING: Could not remove breakpoint @ address 0x000099B8
    140. Removing breakpoint @ address 0x0000AB18, Size = 2
    141. WARNING: Could not remove breakpoint @ address 0x0000AB18
    142. Removing breakpoint @ address 0x0000AB56, Size = 2
    143. WARNING: Could not remove breakpoint @ address 0x0000AB56
    144. Removing breakpoint @ address 0x0000ABE6, Size = 2
    145. WARNING: Could not remove breakpoint @ address 0x0000ABE6
    146. WARNING: Failed to read memory @ address 0x00000000
    147. Read 4 bytes @ address 0x00000000 (Data = 0x00007FFF)
    148. WARNING: Failed to read memory @ address 0x00000000
    149. Read 4 bytes @ address 0x00000000 (Data = 0x00007FFF)
    150. Reading 140 bytes @ address 0x00000000
    151. WARNING: Failed to read memory @ address 0x00000000
    152. WARNING: Failed to read memory @ address 0x00000000
    153. Read 2 bytes @ address 0x00000000 (Data = 0x7FFF)
    154. Reading 100 bytes @ address 0x00000001
    155. WARNING: Failed to read memory @ address 0x00000001
    156. WARNING: Failed to read memory @ address 0x00000000
    157. Read 2 bytes @ address 0x00000000 (Data = 0x7FFF)
    158. Reading 100 bytes @ address 0x00000002
    159. WARNING: Failed to read memory @ address 0x00000002
    160. WARNING: Failed to read memory @ address 0x00000002
    161. Read 2 bytes @ address 0x00000002 (Data = 0x7FFF)
    162. Reading 100 bytes @ address 0x00000003
    163. WARNING: Failed to read memory @ address 0x00000003
    164. WARNING: Failed to read memory @ address 0x00000002
    165. Read 2 bytes @ address 0x00000002 (Data = 0x7FFF)
    166. Reading 100 bytes @ address 0x00000004
    167. WARNING: Failed to read memory @ address 0x00000004
    168. WARNING: Failed to read memory @ address 0x00000004
    169. Read 2 bytes @ address 0x00000004 (Data = 0x7FFF)
    170. Reading 100 bytes @ address 0x00000005
    171. WARNING: Failed to read memory @ address 0x00000005
    172. WARNING: Failed to read memory @ address 0x00000004
    173. Read 2 bytes @ address 0x00000004 (Data = 0x7FFF)
    here is and example where it simple refuses to connect:
    25. Connecting to J-Link failed. Connected correctly?
    26. GDBServer will be closed...
    27. Shutting down...
    If again unplug and replug after several minutes, it works again.
    I have used Apples "USB Prober" Dev tool and note that I have to wait until the device completely disappears from the "Bus Probe" before it will work again.
    This is extremely frustrating.
    I tried to find the J-Link Commander tool listed on the downloads, but I cannot find it for OSX, does it exist four OSX?
    Cheers
    Douglas
    The post was edited 1 time, last by Douglas ().
  • *** UPDATE ****
    The board is actually a STK-3700 not a STK-3600 from Energy Micro (aka SILabs)
    I have moved the STK-3700 onto a WIn7 machine and am able to remotely debug via JLinkGDBServer on the Win7 machine from Eclipse on OSX with my own boards USB connected back to OSX and using "SerialTools" from the Apple App store as a terminal emulator for the USB CDC serial port my device uses. This works fine (v4.78d of JLink)
    I have also removed Apple's "USB Prober" DevTool for debug and tracing too and tried again fully under OSX, but before every debug session I have to completely power off the STK-3700 and then try to debug and more often than not I have to do that multiple times before it will work.
    The only USB devices I have are the STK-3700 and my own board being debugged.
    Sorry to hear that you are running into problems.
    We are not aware of such issues.
    Please note that there is no direct support from SEGGER for the Energy Micro on-board debug probe (which is J-Link compatible but maintained by Energy Micro, now SiLabs).
    Can you provide the ELF file you are trying to download and debug under OS X?
    We will then give it a try here.
    PS:
    Just repeating that this frustrating for you, is not productive in any way... We heard you the first time..
    - Alex
    Yes, of course:
    JLinkExe
    - Alex
    Thanks for the feedback :)
    To try and simplify things I have created a smaller application that started to work the first time I download, but when I "Suspend" the application (Using Eclipse) it fails to read the memory and I can never re-flash or restart the debugging unless I unplug the STK3700 for a few minutes and then start all over. Note this is connecting to my own EFM32LG330F256 board.
    The same thing happens using the gdb CLI.
    If I then remove the STK3700 from my OSX machine and plug it into my Windows machine and I can remotely debug using the gdb server box, I can properly debug, change the code, ref lash, suspend, stop, single step, etc.
    When I reconnect back to my OSX machine, around 20% of the time I can initially load the code, it will sometimes run to the first time I suspend the code, then I cannot re-flash or restart the debug session.
    Here is a sample of the messages I get when connected to OSX:
    GDBInit file: none
    Verify download: on
    Silent mode: off
    Single run mode: on
    J-Link script: none
    Hardware: V7.00
    S/N: 440004343
    Feature(s): GDB
    Target voltage: 3.32 V
    Resetting target
    ...Target halted (PC = 0x0000825C)
    R0 = 00000000, R1 = 00006E90, R2 = 00006E90, R3 = 00006E8F
    R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
    R12= 00000052, R13= 20008000, MSP= 20008000, PSP= 20006488
    R14(LR) = FFFFFFFF, R15(PC) = 0000825C
    Downloading 12556 bytes @ address 0x00000000 - Verified OK
    Downloading 4 bytes @ address 0x0000310C - Verified OK
    Downloading 8 bytes @ address 0x00003110 - Verified OK
    Downloading 160 bytes @ address 0x00003118 - Verified OK
    Downloading 32 bytes @ address 0x000031B8 - Verified OK
    Writing register (PC = 0x000000dc)
    Read 2 bytes @ address 0x000012CC (Data = 0x2300)
    Resetting target
    R0 = 00000000, R1 = 00000000, R2 = 00000010, R3 = 669C55EF
    R12= 10000670, R13= 20008000, MSP= 20008000, PSP= 20006488
    Setting breakpoint @ address 0x000012CC, Size = 2, BPHandle = 0x0002
    Debugger requested to halt target...
    Removing breakpoint @ address 0x000012CC, Size = 2
    WARNING: Could not remove breakpoint @ address 0x000012CC
    Reading 100 bytes @ address 0x00000000
    WARNING: Failed to read memory @ address 0x00000018
    Read 2 bytes @ address 0x00000018 (Data = 0x7FFF)
    Reading 108 bytes @ address 0x00000001
    Reading 108 bytes @ address 0x00000002
    Reading 108 bytes @ address 0x00000003
    Reading 108 bytes @ address 0x00000004
    Reading 108 bytes @ address 0x00000005
    If I then Exit the debug session and close Eclipse down completely and try:
    SEGGER J-Link Commander V4.82 ('?' for help)
    Compiled Mar 10 2014 19:13:30
    Can not connect to J-Link via USB.
    I then removed the STK3700 from the USB port and replugged it in after about 15 seconds and re-ran JLinkexe:
    DLL version V4.82, compiled Mar 10 2014 19:13:25
    Hardware: V7.00
    S/N: 440004343
    Feature(s): GDB
    VTarget = 1.157V
    No devices found on JTAG chain. Trying to find device on SWD.
    WARNING: RESET (pin 15) high, but should be low. Please check target hardware.
    No device found on SWD.
    Did not find any core.
    Failed to identify target. Trying again with slow (4 kHz) speed.
    No device found at all. Selecting JTAG as default target interface.
    *** J-Link V4.82 Error ***
    Debugger tries to select target interface JTAG.
    This interface is not supported by the connected emulator.
    Selection will be ignored by the DLL.
    I then checked my circuit diagram and the reset pin from the debug port on the STK3700 goes directly to the reset pin on the EFM32LG330F256 and has no other components on it.
    I Then unplugged the STK-3700 for a minute, and retried and got:
    Hardware: V7.00
    S/N: 440004343
    Feature(s): GDB
    VTarget = 3.336V
    Info: Found SWD-DP with ID 0x2BA01477
    Info: Found Cortex-M3 r2p1, Little endian.
    Info: FPUnit: 6 code (BP) slots and 2 literal slots
    Info: TPIU fitted.
    Info: ETM fitted.
    Cortex-M3 identified.
    Target interface speed: 100 kHz
    J-Link>f
    Hardware: V7.00
    Cheers
    Douglas
  • I have tried the V4.83a beta version and from a freshly plugged in device I get:
    1. SEGGER J-Link GDB Server V4.83a (beta) Command Line Version
    2. JLinkARM.dll V4.83a (DLL compiled Mar 25 2014 19:17:44)
    9. Generate logfile: on
    20. Target device: EFM32LG330F256
    22. Target interface speed: 1000kHz
    27. Hardware: V7.00
    28. S/N: 440004343
    29. Feature(s): GDB
    31. Target voltage: 3.32 V
    37. Target interface speed set to 2667 kHz
    40. ...Target halted (PC = 0x00008294)
    41. R0 = 200065AC, R1 = 00000000, R2 = 20006740, R3 = 20006740
    42. R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
    44. R12= 00000052, R13= 20008000, MSP= 20008000, PSP= 20006488
    45. R14(LR) = FFFFFFFF, R15(PC) = 00008294
    49. Target interface speed set to 2000 kHz
    52. Semihosting I/O set to TELNET and GDB Client
    55. Downloading 16096 bytes @ address 0x00000000 - Verified OK
    56. Downloading 16144 bytes @ address 0x00003EE0 - Verified OK
    57. Downloading 16128 bytes @ address 0x00007DF0 - Verified OK
    58. Downloading 16144 bytes @ address 0x0000BCF0 - Verified OK
    59. Downloading 9820 bytes @ address 0x0000FC00 - Verified OK
    60. Downloading 8 bytes @ address 0x0001225C - Verified OK
    61. Downloading 2276 bytes @ address 0x00012264 - Verified OK
    62. Read 4 bytes @ address 0x00008294 (Data = 0x47804807)
    63. Read 2 bytes @ address 0x00006546 (Data = 0x9B01)
    64. Read 2 bytes @ address 0x00006576 (Data = 0x484A)
    65. Read 2 bytes @ address 0x00007434 (Data = 0xF7FF)
    66. Read 2 bytes @ address 0x00007434 (Data = 0xF7FF)
    67. Read 2 bytes @ address 0x00006B04 (Data = 0x4812)
    68. Read 2 bytes @ address 0x00006B0E (Data = 0x4B12)
    69. Read 2 bytes @ address 0x00007434 (Data = 0xF7FF)
    70. Read 2 bytes @ address 0x00007434 (Data = 0xF7FF)
    71. Read 2 bytes @ address 0x00007434 (Data = 0xF7FF)
    72. Resetting target
    73. Halting target CPU...
    74. ...Target halted (PC = 0x00008294)
    75. R0 = 40088000, R1 = 00000000, R2 = 00000010, R3 = 00000000
    76. R4 = 100006FC, R5 = 10000754, R6 = 10000754, R7 = 00000000
    77. R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000
    78. R12= 10000670, R13= 20008000, MSP= 20008000, PSP= 20006488
    79. R14(LR) = FFFFFFFF, R15(PC) = 00008294
    80. XPSR 01000000, APSR 00000000, EPSR 01000000, IPSR 00000000
    81. CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00
    82. Reading all registers
    83. Read 4 bytes @ address 0x00008294 (Data = 0x47804807)
    84. Setting breakpoint @ address 0x00006576, Size = 2, BPHandle = 0x0002
    85. Setting breakpoint @ address 0x00007434, Size = 2, BPHandle = 0x0003
    86. Starting target CPU...
    87. ERROR: Communication timed out: Requested 24 bytes, received 0 bytes !
    88. Could not start CPU core. (ErrorCode: -1)
    89. ...Target halted (PC = 0x00000000)
    90. Reading all registers
    91. Removing breakpoint @ address 0x00006576, Size = 2
    92. WARNING: Could not remove breakpoint @ address 0x00006576
    93. Removing breakpoint @ address 0x00007434, Size = 2
    94. WARNING: Could not remove breakpoint @ address 0x00007434
    95. WARNING: Failed to read memory @ address 0x00000000
    96. Read 4 bytes @ address 0x00000000 (Data = 0x00007FFF)
    97. WARNING: Failed to read memory @ address 0x00000000
    98. Read 4 bytes @ address 0x00000000 (Data = 0x00007FFF)
    99. Reading 100 bytes @ address 0x00000000
    100. WARNING: Failed to read memory @ address 0x00000000
    101. WARNING: Failed to read memory @ address 0x00000000
    102. Read 2 bytes @ address 0x00000000 (Data = 0x7FFF)
    103. Reading 108 bytes @ address 0x00000001
    104. WARNING: Failed to read memory @ address 0x00000001
    105. WARNING: Failed to read memory @ address 0x00000000
    106. Read 2 bytes @ address 0x00000000 (Data = 0x7FFF)
    107. Reading 108 bytes @ address 0x00000002
    108. WARNING: Failed to read memory @ address 0x00000002
    109. WARNING: Failed to read memory @ address 0x00000002
    110. Read 2 bytes @ address 0x00000002 (Data = 0x7FFF)
    111. Reading 108 bytes @ address 0x00000003
    112. WARNING: Failed to read memory @ address 0x00000003
    113. WARNING: Failed to read memory @ address 0x00000002
    114. Read 2 bytes @ address 0x00000002 (Data = 0x7FFF)
    115. Reading 108 bytes @ address 0x00000004
    116. WARNING: Failed to read memory @ address 0x00000004
    117. WARNING: Failed to read memory @ address 0x00000004
    118. Read 2 bytes @ address 0x00000004 (Data = 0x7FFF)
    119. Reading 108 bytes @ address 0x00000005
    120. WARNING: Failed to read memory @ address 0x00000005
    121. WARNING: Failed to read memory @ address 0x00000004
    122. Read 2 bytes @ address 0x00000004 (Data = 0x7FFF)
    Any thoughts?
    Cheers
    Douglas
  • I have just upgraded to v4.84 and my MAC rebooted after detecting a memory leak, possibly in the JLinkGDBServer:
    Here is the log that was generated and sent to Apple:
    1. Sat Mar 29 16:20:09 2014
    2. panic(cpu 2 caller 0xffffff8017c5220d): "zalloc: zone map exhausted while allocating from zone socache zone, likely due to memory leak in zone socache zone (2609041248 total bytes, 1289052 elements allocated)"@/SourceCache/xnu/xnu-2422.90.20/osfmk/kern/zalloc.c:2494
    3. Backtrace (CPU 2), Frame : Return Address
    4. 0xffffff8025efbc80 : 0xffffff8017c22fa9
    5. 0xffffff8025efbd00 : 0xffffff8017c5220d
    6. 0xffffff8025efbe00 : 0xffffff8018011533
    7. 0xffffff8025efbe20 : 0xffffff8018011642
    8. 0xffffff8025efbe70 : 0xffffff8018011a7d
    9. 0xffffff8025efbeb0 : 0xffffff801801e4a0
    10. 0xffffff8025efbf10 : 0xffffff801801e380
    11. 0xffffff8025efbf50 : 0xffffff801803e363
    12. 0xffffff8025efbfb0 : 0xffffff8017cf3b26
    13. BSD process name corresponding to current thread: JLinkGDBServer
    14. Mac OS version:
    15. 13C64
    16. Kernel version:
    17. Darwin Kernel Version 13.1.0: Thu Jan 16 19:40:37 PST 2014; root:xnu-2422.90.20~2/RELEASE_X86_64
    18. Kernel UUID: 9FEA8EDC-B629-3ED2-A1A3-6521A1885953
    19. Kernel slide: 0x0000000017a00000
    20. Kernel text base: 0xffffff8017c00000
    21. System model name: iMac14,2 (Mac-27ADBB7B4CEE8E61)
    22. System uptime in nanoseconds: 602607367901984
    23. vm objects:29536864
    24. vm object hash entri:4120800
    25. VM map entries:4946400
    26. Reserved VM map entr:2015680
    27. pv_list:19894272
    28. vm pages:146889432
    29. kalloc.32:1604736
    30. kalloc.64:102517632
    31. kalloc.128:174862336
    32. kalloc.256:10067968
    33. kalloc.512:13991936
    34. kalloc.1024:5935104
    35. kalloc.2048:2027520
    36. kalloc.4096:2732032
    37. kalloc.8192:8708096
    38. mem_obj_control:1651584
    39. wait queue links:1370880
    40. ipc ports:6401440
    41. threads:1436304
    42. vnodes:31713840
    43. namecache:10958880
    44. HFS node:42766608
    45. HFS fork:13008896
    46. cluster_write:9857752
    47. decmpfs_cnode:1939392
    48. buf.8192:38903808
    49. ubc_info zone:8714992
    50. socache zone:2609041248
    51. vnode pager structur:3595600
    52. Kernel Stacks:2392064
    53. PageTables:83845120
    54. Kalloc.Large:25791964
    55. Backtrace suspected of leaking: (outstanding bytes: 2534048)
    56. 0xffffff8017c51d13
    57. 0xffffff8018011533
    58. 0xffffff8018011642
    59. 0xffffff8018011a7d
    60. 0xffffff801801e4a0
    61. 0xffffff801801e380
    62. 0xffffff801803e363
    63. last loaded kext at 602511689809096: com.apple.driver.AppleUSBCDCECMData 4.2.1b5 (addr 0xffffff7f9a2e3000, size 28672)
    64. last unloaded kext at 602468921991897: com.apple.driver.AppleUSBCDC 4.2.1b5 (addr 0xffffff7f9a2d4000, size 16384)
    65. loaded kexts:
    66. com.apple.driver.AppleUSBCDCECMData 4.2.1b5
    67. com.apple.driver.AppleUSBCDCACMData 4.2.1b5
    68. com.apple.driver.AppleUSBCDC 4.2.1b5
    69. com.apple.filesystems.afpfs 11.1
    70. com.apple.nke.asp-tcp 8.0.1
    71. com.apple.filesystems.smbfs 2.0.1
    72. com.apple.driver.AudioAUUC 1.60
    73. com.apple.driver.AppleHWSensor 1.9.5d0
    74. com.apple.driver.AppleBluetoothMultitouch 80.14
    75. com.apple.driver.ApplePlatformEnabler 2.0.9d1
    76. com.apple.driver.AGPM 100.14.15
    77. com.apple.driver.X86PlatformShim 1.0.0
    78. com.apple.filesystems.autofs 3.0
    79. com.apple.iokit.IOBluetoothSerialManager 4.2.3f10
    80. com.apple.driver.AppleMikeyHIDDriver 124
    81. com.apple.driver.AppleMikeyDriver 2.6.0f1
    82. com.apple.driver.AppleHDA 2.6.0f1
    83. com.apple.iokit.IOUserEthernet 1.0.0d1
    84. com.apple.Dont_Steal_Mac_OS_X 7.0.0
    85. com.apple.driver.AppleHWAccess 1
    86. com.apple.driver.AppleUpstreamUserClient 3.5.13
    87. com.apple.GeForce 8.2.4
    88. com.apple.driver.AppleBacklight 170.3.5
    89. com.apple.driver.AppleMCCSControl 1.1.12
    90. com.apple.driver.AppleThunderboltIP 1.1.2
    91. com.apple.driver.AppleIntelHD5000Graphics 8.2.4
    92. com.apple.iokit.BroadcomBluetoothHostControllerUSBTransport 4.2.3f10
    93. com.apple.driver.AppleLPC 1.7.0
    94. com.apple.driver.AppleSMCLMU 2.0.4d1
    95. com.apple.driver.AppleIntelFramebufferAzul 8.2.4
    96. com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 1.0.0d1
    97. com.apple.AppleFSCompression.AppleFSCompressionTypeZlib 1.0.0d1
    98. com.apple.BootCache 35
    99. com.apple.driver.AppleUSBHub 666.4.0
    100. com.apple.driver.XsanFilter 404
    101. com.apple.iokit.IOAHCIBlockStorage 2.5.1
    102. com.apple.driver.AppleSDXC 1.5.2
    103. com.apple.driver.AirPort.Brcm4360 831.21.63
    104. com.apple.iokit.AppleBCM5701Ethernet 3.8.1b2
    105. com.apple.driver.AppleAHCIPort 3.0.0
    106. com.apple.driver.AppleUSBXHCI 670.4.0
    107. com.apple.driver.AppleRTC 2.0
    108. com.apple.driver.AppleACPIButtons 2.0
    109. com.apple.driver.AppleHPET 1.8
    110. com.apple.driver.AppleSMBIOS 2.1
    111. com.apple.driver.AppleACPIEC 2.0
    112. com.apple.driver.AppleAPIC 1.7
    113. com.apple.nke.applicationfirewall 153
    114. com.apple.security.quarantine 3
    115. com.apple.driver.AppleUSBCDCACMControl 4.2.1b5
    116. com.apple.security.SecureRemotePassword 1.0
    117. com.apple.driver.AppleBluetoothHIDKeyboard 170.15
    118. com.apple.driver.AppleHIDKeyboard 170.15
    119. com.apple.driver.IOBluetoothHIDDriver 4.2.3f10
    120. com.apple.driver.AppleMultitouchDriver 245.13
    121. com.apple.kext.triggers 1.0
    122. com.apple.iokit.IOSerialFamily 10.0.7
    123. com.apple.driver.DspFuncLib 2.6.0f1
    124. com.apple.vecLib.kext 1.0.0
    125. com.apple.iokit.IOAudioFamily 1.9.5fc2
    126. com.apple.kext.OSvKernDSPLib 1.14
    127. com.apple.iokit.KLog 650.4.0
    128. com.apple.iokit.IOBluetoothFamily 4.2.3f10
    129. com.apple.nvidia.driver.NVDAGK100Hal 8.2.4
    130. com.apple.nvidia.driver.NVDAResman 8.2.4
    131. com.apple.iokit.IOAcceleratorFamily 98.14
    132. com.apple.driver.AppleSMBusPCI 1.0.12d1
    133. com.apple.driver.AppleBacklightExpert 1.0.4
    134. com.apple.driver.AppleSMBusController 1.0.11d1
    135. com.apple.driver.X86PlatformPlugin 1.0.0
    136. com.apple.driver.AppleThunderboltEDMSink 2.1.3
    137. com.apple.iokit.IOSurface 91
    138. com.apple.iokit.IOBluetoothHostControllerUSBTransport 4.2.3f10
    139. com.apple.driver.IOPlatformPluginFamily 5.7.0d10
    140. com.apple.iokit.IONDRVSupport 2.4.1
    141. com.apple.driver.AppleSMC 3.1.8
    142. com.apple.driver.AppleHDAController 2.6.0f1
    143. com.apple.iokit.IOHDAFamily 2.6.0f1
    144. com.apple.AppleGraphicsDeviceControl 3.4.35
    145. com.apple.iokit.IOAcceleratorFamily2 98.14
    146. com.apple.iokit.IOGraphicsFamily 2.4.1
    147. com.apple.iokit.IOSCSIArchitectureModelFamily 3.6.6
    148. com.apple.driver.AppleUSBMergeNub 650.4.0
    149. com.apple.driver.AppleUSBComposite 656.4.1
    150. com.apple.driver.AppleThunderboltDPOutAdapter 3.1.7
    151. com.apple.driver.AppleThunderboltDPInAdapter 3.1.7
    152. com.apple.driver.AppleThunderboltDPAdapterFamily 3.1.7
    153. com.apple.driver.AppleThunderboltPCIDownAdapter 1.4.5
    154. com.apple.iokit.IOUSBUserClient 660.4.2
    155. com.apple.driver.AppleThunderboltNHI 2.0.1
    156. com.apple.iokit.IOThunderboltFamily 3.2.7
    157. com.apple.iokit.IO80211Family 630.35
    158. com.apple.iokit.IOEthernetAVBController 1.0.3b4
    159. com.apple.driver.mDNSOffloadUserClient 1.0.1b5
    160. com.apple.iokit.IONetworkingFamily 3.2
    161. com.apple.iokit.IOAHCIFamily 2.6.5
    162. com.apple.iokit.IOUSBFamily 675.4.0
    163. com.apple.driver.AppleEFINVRAM 2.0
    164. com.apple.driver.AppleEFIRuntime 2.0
    165. com.apple.iokit.IOHIDFamily 2.0.0
    166. com.apple.iokit.IOSMBusFamily 1.1
    167. com.apple.security.sandbox 278.11
    168. com.apple.kext.AppleMatch 1.0.0d1
    169. com.apple.security.TMSafetyNet 7
    170. com.apple.driver.AppleKeyStore 2
    171. com.apple.driver.DiskImages 371.1
    172. com.apple.iokit.IOStorageFamily 1.9
    173. com.apple.iokit.IOReportFamily 23
    174. com.apple.driver.AppleFDEKeyStore 28.30
    175. com.apple.driver.AppleACPIPlatform 2.0
    176. com.apple.iokit.IOPCIFamily 2.9
    177. com.apple.iokit.IOACPIFamily 1.4
    178. com.apple.kec.pthread 1
    179. com.apple.kec.corecrypto 1.0
    180. Model: iMac14,2, BootROM IM142.0118.B00, 4 processors, Intel Core i5, 3.4 GHz, 8 GB, SMC 2.15f2
    181. Graphics: NVIDIA GeForce GTX 775M, NVIDIA GeForce GTX 775M, PCIe, 2048 MB
    182. Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x02FE, 0x45424A3430554738454655352D474E4C2D46
    183. Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x02FE, 0x45424A3430554738454655352D474E4C2D46
    184. AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x111), Broadcom BCM43xx 1.0 (6.30.223.154.63)
    185. Bluetooth: Version 4.2.3f10 13477, 3 services, 23 devices, 1 incoming serial ports
    186. Network Service: Wi-Fi, AirPort, en1
    187. Serial ATA Device: APPLE HDD WD10EZES-40UFAA0, 1 TB
    188. USB Device: EFM32 USB CDC serial port device
    189. USB Device: FaceTime HD Camera (Built-in)
    190. USB Device: BRCM20702 Hub
    191. USB Device: Bluetooth USB Host Controller
    192. USB Device: EFM32
    193. Thunderbolt Bus: iMac, Apple Inc., 23.10
    Cheers
    Douglas
  • Hi Douglas,
    We possibly found the issue. Cannot guarantee it, but the behavior looks quite the same but under other circumstances.
    Note: It *only* shows up with the OB on the Energy Micro board (which is not directly maintained & supported by SEGGER).
    It does not show up with any "full" J-Link.
    We are planning to have a new version by the end of this week.
  • Hi Douglas,
    Should be fixed in V4.84a: segger.com/jlink-software.html
  • Hi Again,
    I have downloaded v4.84a and the very first time I connect to my board it works perfectly and I download into flash and can debug, etc.
    BUT, when I stop, then update my code and re-download, I again get the time out errors.
    I have to then unplug the STK3700, wait a few minutes and plug back in and again, the first download and debug works, but no subsequent download to flash and debugs work.
    More than happy if you want me to test a version that perhaps generates more debug messages if that helps to diagnose the issue.
    Thanks for your help to date.
    Cheers
    Douglas
  • Hi Douglas,
    We need a reproduction scenario which allows us to reproduce the problem here in house on an eval board.
    So far, we are not aware of *any* problems with the current release.
    - Alex
    I have returned to try 4.86 which I noticed had some OSX fixes that might address my issue.
    However, it now fails every time when the flash has completed and JLink is starting the CPU:
    J-Link found 1 JTAG device, Total IRLen = 4
    JTAG ID: 0x2BA01477 (Cortex-M3)
    Connected to target
    Target interface speed set to 1000 kHz
    Resetting target
    ...Target halted (PC = 0x00008B9C)
    R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000001
    R12= 00000000, R13= 20008000, MSP= 20008000, PSP= 20006D00
    R14(LR) = FFFFFFFF, R15(PC) = 00008B9C
    WARNING: Unknown packet received: "qXfer:threads:read::0,fff"
    Downloading 16112 bytes @ address 0x00003EE0
    Downloading 16160 bytes @ address 0x00007DD0
    Downloading 16192 bytes @ address 0x0000BCF0
    Downloading 3812 bytes @ address 0x0000FC30
    Downloading 8 bytes @ address 0x00010B14
    Downloading 2244 bytes @ address 0x00010B1C
    Read 4 bytes @ address 0x00008B9C (Data = 0x47804807)
    Read 2 bytes @ address 0x00006830 (Data = 0xF01E)
    Read 2 bytes @ address 0x00007C92 (Data = 0xF7FE)
    Read 2 bytes @ address 0x00006848 (Data = 0x9B01)
    Resetting target
    Setting breakpoint @ address 0x00006830, Size = 2, BPHandle = 0x0002
    Setting breakpoint @ address 0x00006848, Size = 2, BPHandle = 0x0003
    Setting breakpoint @ address 0x00007C92, Size = 2, BPHandle = 0x0004
    ...Breakpoint reached @ address 0x00007C92
    Removing breakpoint @ address 0x00006830, Size = 2
    Removing breakpoint @ address 0x00006848, Size = 2
    Removing breakpoint @ address 0x00007C92, Size = 2
    Read 4 bytes @ address 0x00007C92 (Data = 0xFE1FF7FE)
    Reading 64 bytes @ address 0x20006D00
    GDB closed TCP/IP connection
    I notice that the
    is a new message I have not seem in the previous releases, any ideas?
    If I try the GDBServer again I get:
    SEGGER J-Link GDB Server V4.86 Command Line Version
    JLinkARM.dll V4.86 (DLL compiled Jun 6 2014 19:08:58)
    GDBInit file: none
    Accept remote connection: yes
    Verify download: off
    Silent mode: off
    Single run mode: off
    J-Link script: none
    Target device: unspecified
    Target interface: JTAG
    Shutting down...
    or JLinkExe
    $ JLinkExe
    SEGGER J-Link Commander V4.86 ('?' for help)
    Compiled Jun 6 2014 19:09:03
    If you want me to try and capture any other messages, or if you are able to provide a version for OSX that outputs debug statements, I am more than happy to help diagnose exactly what is not working and I appreciate your help!
    Thanks in advance.
    Cheers
    Douglas
    I notice that the
    Unfortunately, this has been introduced in V4.86, since support for some new commands, sent by GDB, has been implemented.
    This implementation was faulty.
    Corrected in V4.86a. Sorry for any inconveniences caused.
    V4.86a: segger.com/jlink-software.html
    - Alex
