Trace with SWO or buffer and STM32MP257F (Cortex M33) using J-trace
  • I have an STM32Mp257F board with a MIPI 10 connector for debug. If I attach this to my J-Trace by using the left half of the MIPI 20 cable, I am able to debug with Ozone successfully. :thumbup:
    The hope for this setup is to be able to do any sort of instruction tracing. I have tried many combinations of trace settings, both with the J-Trace connected as JTAG and SWD, yet nothing seems to work. I do not expect "trace pins" to be a viable option due to their not being present on the MIPI 10 connector. Would that configuration be expected to work if I had a MIPI 20 on an STM32MP257F board?
    The M33 is running at 400 MHz. Is there some sort of enable that needs to happen in a script or in the firmware? What is expected to work?
    Hoping for any tips! ?(
    For buffer tracing the MIPI10 connector is typically sufficient.
    However your target device has to meet certain requirements for buffer tracing to work:
    https://kb.segger.com/Arm_trace_tech…race_components
    If your target device meets these requirements it is typically sufficient to set the trace source in Ozone to "Trace Buffer".
    With some multi core target devices it may be additionally needed to set the base addresses for the Coresight components that the J-Trace Pro could not autodetect:
    https://kb.segger.com/Arm_trace_tech…mponents_failed
    Regarding SWO. On more complex devices is it usually required to init the device/board specific SWO pin via a .JLinkScript.
    https://kb.segger.com/SWO
    In Ozone currently only SWO/ITM printf via stimulus ports is available.
    Instruction tracing via SWO pin is on our wish list but without a fix timeschedule.
  • Thank you for your response. I am trying to specify the location of the ETF using your link here:
    Quote from Nino
    kb.segger.com/Arm_trace_techni…f_trace_components_failed
    Once I include the init script, the M33 core is no longer detected.
