My Jlink Base Compact is resetting my device (STM32U585QI) approximately every 8-10 seconds via the reset pin according to the firmware on my device.
This problem began when I started using my new laptop, a Macbook Pro with an M4 chip running Sequoia 15.5. My previous Macbook with the same OSX version and M1 chip does not exhibit this behavior.
I recently uninstalled all segger tools and software from my computer and the issue stopped. Immediately upon reinstalling them my device started resetting. I didn't even start an application or interact with the JLink. I have ensured the OSX version, JLink Firmware, and JLink tool versions are all the same.
Specifications:
Platform: OSX
JLink Type: JLink Base Compact
JLink software version: 7.98b (although I have tried 8.36)
JLink Firmware: V11
Target Device: STM32U585QI
Attempted Solutions:
- Reinstall JLink Firmware
- Remove all JLink/SEGGER files from system and reinstall JLink tools 7.98b
- Different USB ports, i.e. USB Micro on Jlink to usb a hub and JLink to usb A to C adapter directly into PC USB C port
- Disconnecting and reconnecting connections between the target the device and PC
- Tried a script that continually set the rest pin high while target device was connected
- Set VTREF to a static value instead of letting it auto negotiated, tested values of 1.8V and 3.3V
- Our device uses an intermediate debug board, i.e. PC connects to JLink, JLink connects to debug board, debug board connects to target device, and I have tried multiple debug boards and experienced the same issue
Please let me know what additional configuration or debug info can help. Thank you.
