Using SWO for Character Output in Production with J-Link Commander (No Debug)
  • I’m working in a production setup (not a development/debug session), where each board must be prepared before its main flash image is programmed. Our process is (simulated with EVK):
    1. Connect to the MIMXRT1021-EVK via a Segger J-Link (SWD + SWO).
    2. Use J-Link Commander (JLink.exe / JLinkCommander) to load our custom firmware into RAM.
    3. Start execution immediately with the g command.
    In this context I do not attach a debugger or IDE—everything runs “headless” via J-Link Commander scripts. What I’d like to do is have the running firmware emit simple status or log messages over the SWO pin (ITM port 0 → TPIU), so that our production test station can capture and display these messages without stopping the CPU.
    My questions are:
    1. Is it possible to enable and view SWO output purely from J-Link Commander, without starting a full debug session?
    2. If so, what is the exact sequence of J-Link Commander commands to
      • configure the SWO pin protocol and baud rate,
      • enable the ITM stimulus port,
      • and capture the output in the console?
    I’m already comfortable initializing SWO in firmware (DEMCR, TPIU, ITM regs, etc.), but I need to know the proper J-Link Commander commands to turn on the trace port and route its output to the stdout of J-Link Commander.
    Any example scripts or pointers to the relevant manual sections would be greatly appreciated!
    Thank you in advance,
    Max
    The SWO Viewer should be a suitable tool for this use case.
    It is included as part of the J-Link Software & Documentation Pack.
    For instructions on how to attach it to your target, please refer to:
    https://kb.segger.com/J-Link_SWO_Viewer#-swoattach
    Simon
