My emNet version is V3.40.
I've an issue when the network is not really there. I will explain what I mean,
- I have minimum 2 network switches.
- First one is connected to the local network directly.
- Second one is a sitting between first switch and my custom PCB.
- I power the custom PCB which has a firmware communicates with the network for several tasks.
- I then remove the first network switch from the local network while the 2nd network switch is still connected to the custom PCB.
At that stage, 100Mbps LED stays ON and the activity LED goes OFF or ON and stays there depends on at what state it was.
And, all the network operation ceased naturally.
If I directly remove the network from the custom PCB ,it is fine, I get a proper state change inside _OnStateChange event callback.
And I can then notify the user for the issue.
For now, I just ping an IP and wait for an answer? But, I prefer not to use it.
I am probably missing a point when I read the document. Is there a robust way emNet can offer when the network is really disconnected.
Sener
