Hi!
I'm using Ozone 3.38c with a J-Link Pro under Arch Linux, installed from AUR.
Since a few versions, I noticed that Ozone starts one or more JLinkGUIServerExe processes that take 100% CPU after a short while.
What is the purpose of this process?
Hi!
As a workaround, the processes can be killed with killall JLinkGUIServerExe.
Another workaround is to simply rename the JLinkGUIServerExe file:
sudo mv /opt/SEGGER/JLinkGUIServerExe{,_bak}
Surprisingly, this does not have any effect on the Ozone session..
The problem can also be reproduced using telnet:
Good case:
$ /opt/SEGGER/JLinkGUIServerExe &
$ telnet 127.0.0.1 19022
Trying 127.0.0.1...
Connected to 127.0.0.1.
Escape character is '^]'.
J-Link GUI server;V8.12b;
Bad case:
<<< WAIT 10 seconds >>>
Trying 127.0.0.1...
Connection closed by foreign host.
-> JLinkGUIServerExe now takes 100% CPU.
I'll attach an strace log:
strace -o trace.txt -f /opt/SEGGER/JLink/JLinkGUIServerExe
showing a
* succesful open and close of a telnet connection (line 2545 ..)
* 10s wait (line 2665 ..)
.. it then seems to close the server socket in line 2765
* a failed telnet connection
server is now stuck in a 100% CPU loop while calling pselect6 for the already closed server socket.
The JLinkGUIServer is generally responsible for hosting GUI pop-ups to interact with the J-Link, such as warnings, errors, or dialogs for inputting authentication when the target is protected.
We are aware of the issue you reported and have already implemented a fix. The fix will be included in the next version, scheduled for release in the middle of next week.
Simon
