Im working on graphs. No issues with that.
However when i call GRAPH_SCALE_SetFactor function to create a scale, each numbers drawn becomes 0.
If i do not call GRAPH_SCALE_SetFactor when creating a Scale, it works as expected, numbers drawn with respect to pixel units.
Calling GRAPH_SCALE_SetFactor(hScale, 1.0f) does not work either.
What could be the issue?
Library i use is libGUI_v8m_t_vfpv5_soft_OS0.
I create SCALE widgets same as the GRAPH example.
Im using IAR EWARM 9.32.2, and emwin version is 6.46.
I will be very sad if i need to manually draw the scale on the graph
Best Regards,
Ebubekir
