[SOLVED] data sampling / timeline when doing emulated background reads
  • given you can refresh watched data at up to a few Hz in the background on MPUs that don't support the full high speed sampling mechanism over JTAG, why does the Timeline / data sampling?
    using J-Trace with Cortex A5D27 which doesn't support the full high speed background refresh
    this appears in the console
    Hardware setup does not support data sampling.
    Current setup does not support background memory access mode
    Error (84): Failed to start high speed sampling (HSS).
    i don't see why the mechanism for flushing the data from the processor should matter to being able to graph / do stats on a variable ( which does appear in the data sampling window but obviously doesn't update ) given that as the user we know and understand the sampling restrictions of the hardware platform
  • Hi AndyR,
    I'm sorry but I am not able to comprehend the point of your inquiry.
    Could you please describe more clearly what exactly you would like to know or understand?
    -- AlexD
  • you can't graph watched variables when using the emulated background JTAG refreshing [ Cortex A5D27 doesn't support high speed live watches according to ozone so is starting and stopping the MPU to read the values ]
    they do happily slowly update which is fine given you only get 5Hz updating
    but you can't graph the vatiables
  • Hi AndyR,
    please refer to the Ozone user' manual, section 4.6.1, where the hardware requirements for the data sampling window are listed. There you can see that you can control background memory access emulation via the system variable VAR_ALLOW_BMA_EMULATION. Setting this variable correctly should resolve the issue you see.
    In general, if you see the data sampling window populating with data, you should be able to see that content in the data pane of the time line window. If the data sampling window remains empty, data cannot be displayed in the time line window.
    -- AlexD
  • VAR_ALLOW_BMA_EMULATION is on and has been - hence i said I have seen and understood the massive difference in update rates for this mode of operation being limited to 5Hz but sample rate is no issue for this
    this is what happens when i try and use this
    "tick" is added as a watch, set to refresh at 1Hz and it does indeed update in the watch window at 1Hz
    when then try to graph "tick" then you just spit out a bunch of error messages in the console
    which contradicts what the manual / you say
  • Hi AndyR,
    could you please provide a J-Link log and an Ozone log, both recorded during the same session where the issue is reproduced?
    How to create an Ozone log is described in chapter 8 of the Ozone user's manual. Creating a J-Link log file is described here: https://wiki.segger.com/J-Link_DLL#Enable_J-Link_Log_File
    -- AlexD
  • Hi AndyR,
    on which device, exactly do you observe that behavior?
    We shall try to reproduce locally.
    -- AlexD
  • Hi AndyR,
    please accept my apologies for the late response. Busy times...
    Indeed, the support for emulated background memory access for high-speed applications such as the data sampling window in Ozone, is deprecated since quite a long time in the J-Link. Unfortunately the Ozone user's manual does not reflect that yet.
    So, in short: You cannot use data sampling if your device does not support BMA, emulated BMA does not suffice.
    Thank you for pointing that out to us, we will update the user's manual.
    -- AlexD
