[SOLVED] the gnu linker bug for new version of segger
  • dear:
    now i am use the segger studio of v7.3. the gnu linker is used for cortex-m33 but this is some error like "prinops.c:(.text.libc.vfprintf_l+0x5c): undefined reference to `__SEGGER_RTL_vfprintf'".
    and segger linker is ok。
    how to solver this problem for gnu linker ? :thumbup:
    Most likely the library I/O type is not correctly set in the project.
    Please take a look here for more information: https://wiki.segger.com/Embedded_Studio_Library_IO
    SebastianB
  • hi:
    thank your reply.
    you,re right. According to the documentation, SEGGER_RTT_printf can be used. But there,re two question。
    One problem is that the current SEGGER_RTT_printf formatting output has too many restrictions (such as outputting long long), and the application is not compatible with the previous one as below.
    * SEGGER_RTT_printf
    * Function description
    * Stores a formatted string in SEGGER RTT control block.
    * This data is read by the host.
    * Parameters
    * BufferIndex Index of "Up"-buffer to be used. (e.g. 0 for "Terminal")
    * sFormat Pointer to format string, followed by the arguments for conversion
    * Return values
    * >= 0: Number of bytes which have been stored in the "Up"-buffer.
    * < 0: Error
    * Notes
    * (1) Conversion specifications have following syntax:
    * %[flags][FieldWidth][.Precision]ConversionSpecifier
    * (2) Supported flags:
    * -: Left justify within the field width
    * +: Always print sign extension for signed conversions
    * 0: Pad with 0 instead of spaces. Ignored when using '-'-flag or precision
    * Supported conversion specifiers:
    * c: Print the argument as one char
    * d: Print the argument as a signed integer
    * u: Print the argument as an unsigned integer
    * x: Print the argument as an hexadecimal integer
    * s: Print the string pointed to by the argument
    * p: Print the argument as an 8-digit hexadecimal integer. (Argument shall be a pointer to void.)
    The second problem is that there is no sprinf function?
    Did you setup the project correctly for long long printing support? (Code > Printf/Scanf > Printf Integer Support set to "Long Long")
    "sprintf" does of course exist and may simply be used after including "stdio.h".
    Could you check whether the application was prepared correctly?
    SebastianB
  • hi:
    thanks ,i solve it.
    Using Segger's own linker script will automatically link __SEGGER_RTL_vfprintf and __SEGGER_RTL_vfscanf.
    But I use the linker written by GNU format which cannot automatically link __SEGGER_RTL_vfprintf and __SEGGER_RTL_vfscanf.
