why jlink gdb server reponse "Unsupported CPU"?
  • JLinkARM.dll V7.96f (DLL compiled Apr 24 2024 14:25:37)
    Command line: -device Cortex-A55 -if SWD -JLinkScriptFile /home/geduer/wor/jlinkscript.txt -port 5088
    GDBInit file: none
    GDB Server Listening port: 5088
    Terminal I/O port: 2333
    Accept remote connection: yes
    Generate logfile: off
    Verify download: off
    Init regs on start: off
    Silent mode: off
    Single run mode: off
    J-Link Host interface: USB
    J-Link script: /home/geduer/wor/jlinkscript.txt
    J-Link settings file: none
    Target device: Cortex-A55
    Target device parameters: none
    Target interface: SWD
    Target interface speed: 4000kHz
    Target endian: little
    Received monitor command: regs
    Unsupported CPU!
    The regs command is only supported for the ARMv8 AArch32 architecture.
    Since the Cortex-A55 is ARMv8 AArch64, GDB responds with "unsupported CPU."
    Simon
    You could try to read the registers one by one using the "reg" command:
    https://wiki.segger.com/J-Link_GDB_Server#reg
    Simon
