[ABANDONED] J-Link Not connecting to Target Board
  • I tried connecting the J-link EDU mini to my target board via SWD and it can seem to connect. The target board is a custom PCB which features the STM32F401RDT6 microcontroller. I connect the SWDIO and SWDCLK pins together, also the ground and VRef pin. This is what I get as the output :
    Output
    SEGGER J-Link Commander V7.94c (Compiled Jan 3 2024 15:17:49)
    DLL version V7.94c, compiled Jan 3 2024 15:17:37
    Firmware: J-Link EDU Mini V1 compiled Dec 13 2023 14:36:33
    Hardware version: V1.00
    J-Link uptime (since boot): 0d 00h 05m 24s
    S/N: 801043014
    License(s): FlashBP, GDB
    USB speed mode: Full speed (12 MBit/s)
    VTref=3.265V
    J-Link>connect
    Please specify device / core. <Default>: STM32F401RD
    Type '?' for selection dialog
    Device>
    J) JTAG (Default)
    S) SWD
    T) cJTAG
    TIF>S
    Speed>
    Device "STM32F401RD" selected.
    Connecting to target via SWD
    InitTarget() start
    SWD selected. Executing JTAG -> SWD switching sequence.
    Error: Failed to initialized DAP.
    Can not attach to CPU. Trying connect under reset.
    Connecting to CPU via connect under reset failed.
    InitTarget() end - Took 309ms
    Connect failed. Resetting via Reset pin and trying again.
    InitTarget() start
    InitTarget() end - Took 209ms
    Cannot connect to target.
    Any help would be greatly appreciated.
    A good way to approach such an issue is usually the following troubleshooting guide:
    https://wiki.segger.com/J-Link_cannot_…rget_connection
    Additional hints:
    1) The STM32F4 devices allow to set permanent protection (RDP level 2),
    which will effectively disable the debug features of the chip.
    So if RDP level 2 is set, you will never be able to connect to the chip.
    2) In some cases, applications do override the debug pins.
    In such a case you would also have to connect the nRESET pin between J-Link & Device.
    Otherwise the connect under reset can not work, which is basically the only way to connect to the device in such a case.
    I tried your second suggestion and it didn't work. I used a multimeter to check the voltage of the SWDIO and SWDCLK signals, I get 0.16V and 0.5V respectively. Does this tell you something?
    Edited 2 times, last by John1234 (February 19, 2024 at 12:00 AM).
