I noticed that emBuild and SES do not run the pre-build step on the first run after installation (fresh install). I ran into this issue starting in version 7.x of Segger and emBuild.
This came up because our CI server started failing builds after upgrading to 7.x because of a missing version header file that was supposed to be generated by the pre-build step. I had meant to post on the forum quite a while ago but ended up working around the issue by running emBuild twice (first time always fails and the second time the pre-build step will run and the build succeeds).
Our CI pipeline uses a Docker container so it always runs like a fresh install. It's worth pointing out that the pre-build step was working up to version 6.22 but failed when I bumped our CI server to 7.10a (I didn't try the releases between those two versions but hopefully that narrows things down a little bit).
I am happy to collect logs on my end if that would be helpful but I figured I would drop a note here as it would be nice to get that resolved.
