I had a especial Bluetooth solution with Segger that I want to upload to a PCB with a J-Link connector.
The solution is made in Segger.
I had also an extra "out.hex" file that I'm sure I have to use, but I don't know exactly how to use it.
This his ".hex" file is the result of merging the bootloader_setting.hex and the app.hex.
If I compile the solution with build and run, this extra ".hex" file is not involved.
Do you know how to include it?
