Hi!
I keep running into OS_GetMail( m_pMbox, ipc ) triggering OS_ASSERT_CPU_IN_TASK_MODE() which is strange since the function is called by a regular task.
When I set a breakpoint in OS_AssertTaskMode() I can see that OS_InInt contains often the value 0xDD (but also occasionally other values). I think this is not a "normal" value of this variable and that it may somehow have gotten corrupted. Do you have tips on how I could debug this issue ?
