[SOLVED] JLink takes several tries to connect to STM32H730
    with the most recent versions of JLink, the connection to the STM32H730 takes many tries.
    Typically I can connect in the JLink command line, but it takes two tries (the first "connect" will not work, while the second "connect" will work).
    If I re-launch JLink command line, the same behavior happens again (the first "connect" will never work).
    It was working with older JLink versions, so there must be a regression here.
    Florent
  • Can you post a screenshot of the old version that shows that multiple connects in a row work?
    I would be surprised if a popular chip like the STM32H5 series would be that broken in a generic way but nobody else ran into and reported it.
    Are you 100% sure that it was ONLY the J-Link version you changed and not also the target application that changed, which now maybe switches the debug pins to GPIO by accident or similar?
  • Yes, it is working first time on JLink 7.68.
    It is the exact same board, with the same JTrace, and exactly the same connections (the only change is the JLink software).
    However, I am using the JTrace Pro, which I suspect not many people are using, so it may be broken since quite a long time.
    Florent
  • Hi Florent,
    I just gave this a quick try on the STM32H735G-DK (STM32H735).
    I could not test it on an STM32H730, as there are no evaluation boards available as far as I know,
    but both should behave the same from a debug standpoint.
    On our side it worked without any issues with J-Trace Pro V2 Cortex-M (see below).
    Do you have any target application running on your device?
    If so, does the same issue appear after erasing & power-cycling the device?
