Custom Callback with Button
    The goal is to create a button with Multi strings where the strings have different fonts from each other, So as suggested by emwin documentation I have created a custom callback function but I observe that the custom callback is overwriting all the previous set properties. The codes are as follows
    Code
    hButton = WM_GetDialogItem(pMsg->hWin, ID_BUTTON1);
    WM_SetCallback(hButton , CallBack_Button);
    BUTTON_SetBkColor(hButton, BUTTON_CI_UNPRESSED, SKY_BLUE);
    BUTTON_SetBkColor(hButton, BUTTON_CI_PRESSED, HEADER_OFFWHITE);
    BUTTON_SetTextColor(hButton, BUTTON_CI_PRESSED, BASE_BLUE);
    BUTTON_SetTextColor(hButton, BUTTON_CI_UNPRESSED, BASE_BLUE);
    the callback function
    the result would be that
    the entire OFF_WHITE background is replaced by white color except for the two strings. Is there any method where the button_<routines> can be used along with custom modifications.
    Edited 2 times, last by Suresh (April 5, 2023 at 1:08 PM).
    With the default skin of the BUTTON widget the functions BUTTON_SetBkColor() and BUTTON_SetTextColor() are not working. Either set the classic skin or use SKINFLEX properties to change properties like colors.
    If you overwrite the callback function of a widget you can call the default callback function (e.g BUTTON_Callback()) and then draw something.
    Here is a brief example how this could be done:
