[SOLVED] Flasher Secure
    I am currently working with the Flasher Secure (https://www.segger.com/products/produ…flasher-secure/). What I would like to do first is to flash our "old" products using the "unsecured" mode.
    I tried to create the *.cfg and the *.dat and then I upload everything to the flasher using FileZilla. Then I selected the project by sending "#SELECT project_name" after that I tried to send the command #auto but I got the following message: #ERR255:Error while flashing
    However if I use directly J-Flash software I can flash the product without any problem.
    How can I activate and deactivate the secure mode? Is it possible to use the "Flasher Secure" as a normal flasher?
    We would like to use the same flasher for secured and unsecured products.
    Could you please help me?
    Thank you in advance
    Nicola
  • Hello Nicola,
    Could you please open a support ticket for all Flasher Secure related requests?
    https://www.segger.com/support/technical-support/
    Arne
