[CLOSED] The cjtag protocol of jlink cannot be connected.
  • Connecting ‘J-Link’ using ‘USB 50120677’
    Loaded D:/SEGGER/SEGGER Embedded Studio for RISC-V 6.32a/bin/JLink_x64.dll
    Firmware Version: J-Link V11 compiled Apr 27 2041 16:36:21
    DLL Version: 7.22`
    Hardware Version: V11.00
    Target Voltage: 3.354
    Device "SWERV_EH1" selected.
    Current Speed: 1000 kHz
    ConfigTargetSettings() start
    ConfigTargetSettings() end
    TotalIRLen = ?, IRPrint = 0x..000000000000000000000000
    Target connection has been lost
    Edit1:
    Thank you very much
    Edit2:
    Why does this version of J-Link 7.22 issue cjtag connection command different from the official example?
    Edit3:
    Unable to connect the cjtag,It's too hard.
    Edit4:
    The jtag connection is normal
    A couple of things:
    1) Please refrain from spamming in this forum.
    If you want to add information to the thread before anyone answered, please use the "Edit" function.
    I removed the other messages and included it to the original one.
    2) J-Link V7.22 is fairly outdated. Could you please check if it works with the latest version?
    https://www.segger.com/downloads/jlin…cumentationPack
    3) Apparently you already found the article explaining the cJTAG sequnece.
    Have you tried what is mentioned in the note about the short cJTAG sequence?
    https://wiki.segger.com/J-Link_cJTAG_s…onnect_sequence
    1) I am very sorry for not sending emails in a standard manner. I will pay attention to it next time. Thank you very much for your reply.
    2) I have a comment about short cJTAG sequence, and used Jlink command port to set it, but I did not get the expected result.
    3) I checked that the voltage was 3.3V, the interface setting was also cJTAG, the frequency was set at 1000kHz, and the connection using JTAG was normal.
    4) I'd appreciate it if you could give me a better suggestion. thank you.
    5) Could you please provide some waveform sequences about cJTAG? I'm trying to figure out what's wrong with me by comparing the correct wave sequences,Thank you very much .
    Yang
  • As Skvo correctly indicated, you are using a clone/cracked J-Link.
    Please note that the use of such a device in combination with our Software is illegal.
