[SOLVED] JLink Ultra+ flashing problems with S32K144W
    I am currently trying to work with the S32K144W in a project but I am having difficulties using the JLink Ultra+ to flash the device. The JLink is able to connect to the target but fails at this step:
    • Failed to prepare for programming.
    • Could not preserve target memory
    I have attached the console readout of the flash attempt with Ozone.
    I was able to flash it with NXP S32DS but using Ozone or any other SEGGER software I am unable to erase flash or program it. I assume the S32DS is doing some different steps but I wasn't able to pinpoint what was the difference. The jlink commands seems to be very similar.
    I am also at a point where I'd like to partition my device for flash storage and bootloader but I am concerned about locking the device if I can't mass erase and end up protecting the flash.
    *****EDIT*****
    I updated my Ozone version to the latest and obtain the following error:
    Failed to preserve target RAM @ 0x1FFF8000-0x20006FFF.
    *****EDIT*****
    *****EDIT 2****
    I was able to connect via JFlash and erase the whole flash. I was then able to flash with Ozone and also VSCode. I am not sure what happened when erasing the whole flash. I guess there is a flash registers that protect it somewhow. If anyone has any insights on this I would appreciate to understand better the change in behavior.
    *****EDIT 2****
    Thank you for your help!
    Even though the thread is quite old, an answer to the question can be found here:
    https://wiki.segger.com/S32Kxxx#Readou…_internal_flash
