[ABANDONED] RAM Memory Segment Program Section size ignored?
  • Hi, first time posting here.
    I have reserved a section in my RAM memory segment called 'my_non_init' (as highlighted in the screenshot attached) and gave it a size of 0x1000.
    1. A size of 0x1000 stands for 4096 bytes, right?
    2. Since I have reserved 4096 bytes (4kB) but the Memory View shows 24.1kB, why don't I get a compilation error?
    It is essential for me to know the amount of bytes needed/reserved to be able to block the same amount of non initialized memory in the bootloader.
    Thanks!
    in Embedded Studio V5 the size attribute defined the minimum size of a section.
    If you would have placed less than 0x1000 bytes into this section, it would have been expanded.
    See line 6 of the generated linker script:
    Embedded Studio V6.32 adds an additional assert to also make the attribute the maximum size of a section:
    Code
    . = ASSERT(__my_non_init_size__ <= 0x1000 , "error: .my_non_init is larger than specified size");
    If that is the behavior you would expect, you could upgrade to the latest version of Embedded Studio, or change your project to use a custom linker script which includes the additional assert.
    - Johannes
