[CLOSED] flashing .elf file to ECU using Jlink.dll
    I will use the Jlink Plus in Automated test applications for the ECU (NXP S32K312).
    The code is written in C# using the IDE (Visual Studio Professional 2022).
    Namely, I have been having some problems with programming.
    I need the following functions which I didn't find in the Jlink.dll from the SDK:
    - Flashing .elf file to ECU
    - Variables Operations : ReadVariable
    WriteVariable
    - a memory dump of a selected memory section
    - SetBreakpointToFunctionStart(name of function)
    - SetBreakpointToFunctionEnd(name of function)
    - SetBreakpointToAddress()
    - SetBreakpointWhenVariableChange(name of variable)
    - SetBreakpoint
    Are these functions present in the Jlink.dll at all? If not, is there another library for them?
    Or is there a way to call these functions through C# from Ozone tool?
    Kind regards
    We will close this thread as you submitted the very same request via our ticket system already
    and further communication will be handled there.
    Please refrain from sending us the same inquiry via multiple channels.
    Leon
