March 22, 2022 at 12:32 PM #1 I have a board that mounts RT1051 and QSPI. How do I select that type of memory, since I believe HyperFlash is selected by default?best reagardsMax
April 6, 2022 at 3:12 PM #2 Hi Max,Thank you for your inquiry.Currently, the only way to do this is via the following method:https://wiki.segger.com/i.MXRT1050#Enable_FlashloaderWe also have plans to add support for multiply flash banks at the same flash locations.A rough timeline for this is Q3 this year.Until then the method described in the link is the only one unfortunately.Best regards,Fabian
