[SOLVED] Have Ozone disable Watchdog?
  • Working on an STM32L072 system where the watchdog is enabled.
    If execution breaks or is halted manually, the WD will restart the system.
    The STM32L072 has a DBG_APB1_FZ register to "freeze" the WD (among other things) when the core is halted.
    This should be accessible to the J-Link - so how do I do it.
    I see the JLINK_MEM_WriteU32() command in the J-Link script files wiki:
    https://wiki.segger.com/J-Link_script_…_WriteU32.28.29
    and there's Exec.Command() in the Ozone manual.
    So is it just a case of putting Exec.Command( "JLINK_MEM_WriteU32( 0x4001 5808, 0x1800)" ) at an appropriate place in the Ozone project?
    And where would be an "appropriate place" ?
  • Aha: Ozone itself has Target.WriteU32()
    So this seems to work:
    Yes that would be one correct approach.
    You can of course also use a JLinkScript and SetupTarget().
    Ozone generally offers all needed target manipulation actions like read, write, reset etc.
    See the Ozone manual for more information.
    For completeness. Exec.Command is only meant to be used for J-Link Command strings:
    https://wiki.segger.com/J-Link_Command_Strings
