Button press not returning released notification
    I have been working with emWin for quite sometime now. I am currently using buttons for some functionalities in my project. I have a couple of things I would like to get technical answers for.
    1. I have found that sometimes even after the button is released, it wouldn't send NOTIFICATION_RELEASED. This happens only when the buttons are pressed at the edges. Is there a way to solve this problem?
    2. I am displaying images and text boxes. Since the image isn't performing any functions, when pressed on it, creates a touch beep just like functioning part of the scree. Is there a way to disable this so I don't hear a beep when a non-functional object is pressed?
    I look forward to hearing from you. Appreciate all the help.
    Thanks and regards,
    BMD
  • Hi BMD,
    Regarding your first question: I am guessing that a press at the edge of a button results in the touch input being moved out of the BUTTON window.
    When a button is pressed and the touch input is moved out of the window area, the parent window will not receive a WM_NOTIFICATION_CLICKED message (not even when the touch input is being moved back into the window area and released).
    When the touch input is being moved out of a window, the parent window receives a WM_NOTIFICATION_MOVED_OUT.
    Regarding your second issue: You can overwrite the IMAGE callback and react on WM_TOUCH. This will result in all touch input the IMAGE widget receives being handled by your callback.
    Florian
  • Florian,
    Thank you so much for your response.
    1. So you are suggesting that I put my code which I am executing during NOTIFICATION_RELEASED also under WM_NOTIFICATION_MOVED_OUT???
    2. Thank you for the suggestion. Will try that out.
    BMD
