I modified the STemWin(5.44) Font example from the Discovery H747 Cube Examples (version 1.7.0) and made a simple screen with one Button and one text element. The Button, if pressed displays a different text (not pressed = "Disc H747", pressed = "Hello").
Code
case ID_BUTTON_0: // Notifications sent by 'btn_00'
switch(NCode) {
case WM_NOTIFICATION_CLICKED:
// USER START (Optionally insert code for reacting on notification message)
hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_0);
TEXT_SetText(hItem, "Hello");
// USER END
break;
case WM_NOTIFICATION_RELEASED:
TEXT_SetText(hItem, "DiscH747");
// USER END
break;
Display More
Problem: The button functions WM_NOTIFICATION_RELEASED and WM_NOTIFICATION_CLICKED are inverted. (not pressed = "Hello", pressed = "Disc H747"). If I put my text the other way round everything works.
I did the same modification with the Discovery F746 examples (from the Discovery F746Cube Examples) - there is no problem. Has anyone a solution for this problem? Thanks in advance,
Dave
