[SOLVED] IMXRT1020 will not program on secondary pinmux
  • Hi, Current release (V6.62a) and Beta (V6.63b) will not program my device which is on FlashSPI alternate config. Reverting to V6.56d fixes the issue. Interaction sequence is attached. I cannot send the hex file because it's too big for the forum but you can send me PM and I'll send it to you.
    DAVE
    We were able to reproduce not the same issue but a similar one.
    This one will be fixed in the next official version (V6.62b), scheduled to be available later today.
    Could you please give this version a quick try and provide feedback?
    BTW: I noticed that you do *not* perform a reset prior programming.
    This is recommended in order to make sure that the device is in a proper / defined state before programming.
    Erik
  • With this new version, using GDB Server, after an initial 'load' of an elf, 'start' or 'run' for the first time will result in a target disconnect. Restarting GDB Server and gdb allows normal operation thereafter.
    I cannot recreate the previously observed issue at the moment.
    DAVE
  • Thank you for the update.
    We will consider this case as closed for now.
    Erik
