Does emWin have a driver for https://www.waveshare.com/7inch-capacitive-touch-lcd-c.htm ?
7inch Capative Touch LCD
Unfortunately, there is no such driver.
In most cases we simply read the touch data from the touch controller (e.g. via I2C) and pass them forward to emWin.
For single touch this is quite easy. The routine below which polls the touch and gets called periodically from a dedicated task:
C
Display More/********************************************************************* * * PID_X_Exec */ static void PID_X_Exec(void) { TS_StateTypeDef TS_State = {0}; static GUI_PID_STATE StatePID; static int IsTouched; int IsMirrorX; int IsMirrorY; int xSize; int ySize; if (_IsInitialized) { BSP_TS_GetState(&TS_State); // Read touch input StatePID.Layer = _LayerIndex; if (TS_State.touchDetected) { // If touch detected, set up pid statte structure IsTouched = 1; // Remember that last even has been touch down StatePID.Pressed = 1; // Pressed, "down event" // // Get some information about the display orientation and its size // IsMirrorX = LCD_GetMirrorX(); IsMirrorY = LCD_GetMirrorY(); xSize = LCD_GetXSize(); // Depending on the orientation these values are swapped. ySize = LCD_GetYSize(); // Previous x size will y size vice versa if (LCD_GetSwapXYEx(_LayerIndex)) { // // If an axis is mirrored we have to suptract the input from the given axis, be aware that // the axis values might be swapped. That's why we use ySize for x and xSize for y... // StatePID.y = (IsMirrorX) ? ySize - TS_State.touchX[0] : TS_State.touchX[0]; // XY swapped, use x coordinates (ySize is formaer xSize) for the y coordinate StatePID.x = (IsMirrorY) ? xSize - TS_State.touchY[0] : TS_State.touchY[0]; // Same as above but for y } else { StatePID.x = (IsMirrorX) ? xSize - TS_State.touchX[0] : TS_State.touchX[0]; // Nothings swapped but maybe mirrored StatePID.y = (IsMirrorY) ? ySize - TS_State.touchY[0] : TS_State.touchY[0]; } GUI_TOUCH_StoreStateEx(&StatePID); // Pass information to emWin } else { if (IsTouched == 1) { // No touch detected but last event was touch down IsTouched = 0; // Restore IsTouched variable StatePID.Pressed = 0; // Unpressed, "up event" GUI_TOUCH_StoreStateEx(&StatePID); // Since StatePID is declared as static we use the x/y coordinate // from the down event to create an up event. } } } }
With multitouch it is a bit more tricky, but works more or less the same (poll the touch data and pass to emWin). The difference are the multiple touch points and their IDs.emWin offers an API to pass multitouch touch input to emWin. Attached are some examples for different TCs.
Sven -
Thank you. I understand that there is also no draivera for operating the LCD panel.
