I am having problems trying to use J-Flash with my AT91SAM9263-EK evaluation board. The board comes with a pad that you can lay down a NOR flash chip on. It looks like the CPU might not be supported, is this correct? If so how hard would it be to be added. I am currently booting from the NOR flash chip, so there is not problem with the system.
The following is the log from trying to connect:
Connecting ...
- J-Link firmware: V1.20 (J-Link ARM V6 compiled Dec 03 2007 17:34:18
- Using adaptive clocking instead of fixed JTAG speed
- Initializing CPU core (Init sequence) ...
- Initialized successfully
- J-Link found 1 JTAG device. Core ID: 0x0792603F (ARM9)
- Reading CFI info ...
- ERROR: Read memory error @ address 0x00000020, 512 bytes: Communication timeout.
- ERROR: Target system has no power.
- ERROR: Could not find supported CPU core on JTAG chain
- ERROR: Failed to read CFI info
- ERROR: Failed to connect
Thanks in advance,
Ken Woodland
