Hello!
I use OpenFlashLoader for programming EEPROM on my custom board with RM46L852 chip.
v6.18c is working. But JLinkARM.dll from v6.20c or v6.20e is not working: message "Unsupported CPU" appears.
What does it means?
Vitaliy
Hello!
What does it means?
Vitaliy
Hi Vitaliy,
Open Flashloader is supported on Cortex-M/R/A targets.
Could you please provide us with a screenshot of the error message?
Which application (J-Link Commander, J-Flash, 3rd party IDE) do you use with Open FlashLoader?
Hello, Nicklas.
I use JLink.exe.
Here is your template project for Segger Embedded Studio (Cortex A/R core) with smallest modification for working on RM46L852 chip.
Also I add a sample of JLinkDevices.xml for working on my chip.
If you add JLinkARM.dll from Segger JLink v6.20e and JLink.exe in working directory and run test.cmd then you get that log:
QuoteDisplay More>test.cmd
Z:\OpenFlashLoader_CortexAR_Template_EmbeddedStudio>JLink.exe
-device RM46L852_EEPROM -if jtag -autoconnect 1 -jtagconf -1,-1 -speed
2000 -CommanderScript prgEeprom.jlink
SEGGER J-Link Commander V6.18c (Compiled Aug 21 2017 16:47:16)
DLL version V6.20e, compiled Oct 6 2017 17:05:40
Script file read successfully.
Processing script file...J-Link connection not established yet but required for command.
Firmware: J-Link Ultra V4 compiled Oct 6 2017 16:38:09
Hardware version: V4.00
S/N: 504400221
VTref = 3.262V
Target connection not established yet but required for command.
Device "RM46L852_EEPROM" selected.
Connecting to target via JTAG
J-Link script: InitTarget()
J-Link script: found RM48L950 rev.A
TotalIRLen = 10, IRPrint = 0x0011
JTAG chain detection found 2 devices:
#0 Id: 0x4BA00477, IRLen: 04, CoreSight JTAG-DP
#1 Id: 0x2B95502F, IRLen: 06, TI ICEPick
ARM AP[0]: 0x44770001, AHB-AP
ARM AP[1]: 0x24770002, APB-AP
ROMTbl[0][0]: CompAddr: 80001000 CID: B105900D, PID:04-007BBC14 Cortex-R4
Found Cortex-R4 r1p3
6 code breakpoints, 2 data breakpoints
Debug architecture ARMv7.0
Data endian: little
Main ID register: 0x411FC143
TCM Type register: 0x00010001
MPU Type register: 0x00000C00
System control register:
Instruction endian: little
Level-1 instruction cache disabled
Level-1 data cache disabled
MPU disabled
Branch prediction enabled
Cortex-R4 identified.
Reset delay: 0 ms
Reset type NORMAL: Toggle reset pin and halt CPU core.
J-Link script: ResetTarget()Downloading file [16bytes.bin]...
****** Error: FLASH_CMSIS: The connected CPU core is not supported by this flash module.
Error while determining flash info (Bank @ 0x00000000)
Unspecified error -1Reset delay: 0 ms
Script processing completed.
If you change JLinkARM.dll from v6.18c then you get expected log:
DLL version V6.18c, compiled Aug 21 2017 16:46:41
S/N: 504400221
VTref = 3.264V
Data endian: little
MPU disabled
Reset delay: 0 ms
J-Link: Flash download: Bank 0 @ 0x00000000: 1 range affected (16384 bytes)
J-Link:
Flash download: Total time needed: 0.342s (Prepare: 0.030s, Compare:
0.112s, Erase: 0.022s, Program: 0.049s, Verify: 0.119s, Restore: 0.007s)****** Error: Verification failed @ address 0x00000000
Error while programming flash: Verify failed.Reset delay: 0 ms
For v6.18c there is expected verification error because of non-existing eeprom programming algos in my sample.
For v6.20e there is unexpected error: "****** Error: FLASH_CMSIS: The connected CPU core is not supported by this flash module."
Regards, Vitaliy
Hi Vitaliy,
We could reproduce this issue and fixed it internally.
Please find a preliminary version for download here:
download.segger.com/Niklas/JLink_V621c_Preliminary_OpenFlashloaderAR_Fix.7z
Could you please give it a try and provide feedback if it works for you?
Yes, that version is working.
Thanks!
thanks for the feedback and good to hear that it works for you!
