[ABANDONED] Cannot load driver JL2CM3.dll
    I have 2 nRF52 DK, I made a project with MDK Keil and when I selected the debugger as J-Link in debug tab, and error appear saying that it could not load driver JL2CM3.dll
    I tried using J-Link Command to connect with SWD and it work normally. I also tried programming it with the Segger Embedded Studio and it worked. So there is no problem with my DK.
    Is there anyway to replace or to fix the JL2CM3.dll? Thank you!!
    :pinch: :pinch: :pinch: ^^ ^^ ^^ ^^ ^^
    could you please check if the file is actually located in the path specified in the error message?
    If yes, could you please right click it -> properties and provide us with a screenshot of the tab "Details"?
