[SOLVED] JLinkCommander & JLinkDevices.xml
  • Is where any way to add a custom flash loader to the JLinkCommander?
    the latest version 6.16c doesn't work with with my external qspi
    I'm unable to do a full erase of my qspi chip. The latest working version was 6.15e
    Erasing flash [020%]
    ****** Error: Can not read register 15 (R15) while CPU is running
    ****** Error: Can not read register 7 (R7) while CPU is running
    ****** Error: Can not read register 6 (R6) while CPU is running
    ****** Error: Can not read register 5 (R5) while CPU is running
    ****** Error: Can not read register 4 (R4) while CPU is running
    ****** Error: Can not read register 3 (R3) while CPU is running
    ****** Error: Can not read register 2 (R2) while CPU is running
    ****** Error: Can not read register 1 (R1) while CPU is running
    ****** Error: Can not read register 0 (R0) while CPU is running
    100%] Done.
    Verifying flash [100%] Done.
    ****** Error: PC of target system has unexpected value after erasing sector. (PC = 0x00000000)!
    ---------------------------------------------------------------------- Registers -------------------------------------------------------------------------------------
    PC = 00000000
    Current: R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000
    R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
    ****** Error: Can not read register 20 (CFBP) while CPU is running
    ****** Error: CPU is not halted
    J-Link: Flash download: Total time needed: 6.966s (Prepare: 0.095s, Compare: 0.000s, Erase: 6.840s, Program: 0.000s, Verify: 0.000s, Restore: 0.029s)
    ****** Error: PC of target system has unexpected value after restoring target. (PC = 0x00000000)!
    PC = 00000000
    ERROR: Erase returned with error code -5.
    Quote
    Yes, there is:
    https://wiki.segger.com/Adding_Support_for_New_Devices
    This works for all SEGGER utilities: J-Link Commander, GDBServer, J-Flash, ...
    Please note that no support is provided by SEGGER, for custom flashloaders.
    Could you please let us know which device you are using (Vendor + device name) that your QSPI is connected to?
    It would help to check if there is a regression in the current version.
