[SOLVED] JLinkExe flashing PSoC CY8C4247 gives error
    Trying to flash a Cypress PSoC CY8C4247 device using J-Link. Everything seems to work but I always get an error message when doing loadfile:
    However, after resetting, the system seems to start up just fine. It doesn't matter if I decrease the speed, it always gives the error like above.
    What may cause this error message?
    Thanks, Jacob
  • Hi Jacob,
    thanks for your inquiry.
    Could please provide us with the following information?:
    - Which OS do you use? (macOS / Linux)
    - Which J-Link model do you use? Can you please provide the S/N?
    - Which version of the J-Link software do you use?
    - Does this issue also occur with the most recent version of the J-Link software & documentation pack?
    Linux
    J-Link EDU, S/N 269402077
    SEGGER J-Link Commander V6.14c
    Yes.
    Also, I sometimes get this:
    Code
    Downloading file [program.hex]...
    Comparing flash   [100%] Done.
    Erasing flash     [100%] Done.
    Programming flash [100%] Done.
    Verifying flash   [100%] Done.
    J-Link: Flash download: Restarting flash programming due to program error (possibly skipped erasure of half-way erased sector).
    J-Link: Flash download: Skip optimizations disabled for second try.
    Writing target memory failed.
    Your forum messes up newlines in code..!
    Thanks, Jacob
    Edited 3 times, last by wifijacob (April 6, 2017 at 3:07 PM).
  • Hi Jacob,
    the forum software does not work well with \n line endings in code tags, it needs \r\n .
    It will fix your post accordingly.
    Could you please provide us with a J-Link logfile of a session?
    https://wiki.segger.com/J-Link_DLL#Enable_J-Link_Log_File
  • Hi Jacob,
    the "Writing target memory failed." output is caused by write to memory which is called after the flash programming:
    C
    TF12C5700 021:031 JLINK_WriteMem(0x90400000, 0x0040 Bytes, ...) - Data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ... -- CPU_WriteMem(64 bytes @ 0x90400000)  returns 0xFFFFFFFF (1519ms, 1900ms total)
    Does your data file contain data for the address 0x90400000 and / or 0x90300000?
  • The documentation states:
  • Hi Jacob,
    the data file you provide to "loadfile" must only contain the data to be programmed by J-Link.
    Both Checksum and Flash Protection are not memory mapped at these addresses, the Cypress Tools (?) just know what they should represent.
    Stripping everything higher then 0x8000 from the hex file before programming will resolve the issue.
  • Hi Jacob,
    thanks for the update.
    /Closed
