[SOLVED] Automation (SDK) - Using a single JLINK device to access multiple CPUS on JTAG chain
  • Hello
    we are planning a PCB which has 4 M4 CPUs, all connected to one JTAG chain.
    Is it possible to use one JLINK device to access all CPUs?
    In addition, we use JLink SDK for automation. Can you explain how to use JLink SDK in order to communicate with all CPUs (assuming we close and open communication channel for each CPU)
    For example, how to configure so that JLINKARM_Open communicates with a specific CPU.
    Many Thanks!
    Hila
  • Hi Hila,
    Quote
    Yes, it is.
    Quote
    Sorry, I do not understand what you want say. What to mean by "channel"?
    Quote
    JLINKARM_Open() opens a connections to a J-Link, not to a target!
    Connecting to the target is done with JLINKARM_Connect().
    In order to connect to a specific device in the chain (otherwise J-Link connects to the first device that matches the given target device/core name) you need to specify IRPre and DRPre using JLINKARM_ConfigJTAG().
    This is also explained in UM8002.
