[Solved] prevent SystemView from crashing on high load situations
    I'm successfully running SystemView with my STM32F429 target.
    The target runs FreeRTOS with lwip (TCP/IP Stack) and an iperf server. I'm using a J-Trace Cortex-M to connect to the target.
    as soon as I start the bandwithtest, SystemView just displays an error message:
    Invalid packet received. recording stopped.
    the test finishes and shows respectable values.
    I set the SWD frequency to 20MHz, the SystemView Up-Buffer is set to 8KB.
    How can I prevent SystemView from crashing in this benchmark test?
    Best Regards
    Invalid packets are most commonly caused by not locking everything which creates SystemView events or causes context switches.
    Could you make sure that SEGGER_SYSVIEW_LOCK() / SEGGER_RTT_LOCK() are defined to disable all interrrupts which do so?
    To be sure this caused the problem, disable all interrupts.
    Johannes
    Could you give the latest beta (V2.35) SystemViewer a try?
    It fixes one issue which could cause invalid packets in high load situations, too.
    Johannes
    In some cases SystemViewer could have read incomplete events from the target,
    which led to the invalid packet message.
    This has been improved.
    Johannes
  • I upgraded to 2.34 and it crashes no more!
    my next problem will be lots of dropped packets but this is likely because the target interface speed changes from what I defined in the command line of the gdb server.
    Great to read it is working now.
    If you started GDB Server before the SystemVIew recording, the data is read via this J-Link connection.
    In this case you should set a higher interface speed in GDB Server.
    If this does not completely help, you will need to increase the SystemView buffer size.
    Johannes
