[SOLVED] Are WM_MESSAGEs sent witch WM_BroadcastMessage() serialized ?
  • As title says, are WM_MESSAGEs sent with WM_BroadcastMessage() serialized and queued somewhere until consumed or the WM_MESSAGE
    structure passed to WM_BroadcastMessage() must be valid till the message is consumed?
    For example, is the following code legit:
    Code
    void SendSignal(const int id, const int v, void *p)
    	WM_MESSAGE msg;
    	msg.MsgId = id;
    	msg.Data.p = p;
    	msg.Data.v = v;
    	WM_BroadcastMessage(&msg);
    or should WM_MESSAGE be declared static ?
    This would imply I can send only one message at a time and wait until the message is consumed
    before sending another one (or else I must manage myself a message queue).
    This behavior is not documented anywhere as far as i can tell.
    Best regards, Gabriele.
    Edited once, last by Gabri74 (March 31, 2016 at 11:28 AM).
    Your function is legit. WM_BroadcastMessage() sends its own copy of the given message.
    Jörg
