[SOLVED] Thread Awareness for JLinkGDBServer
    Thread awareness for GDB Server is on our todo, but there is currently no fixed schedule for this.
    The Thread awareness in GDB Server will somehow be plugable, so you can provide the required RTOS information via a file.
    Johannes
    In general, GDB is rather dumb as it has no information of the target system when remote debugging.
    OpenOCD and GDB Server are similar, they are the remote server GDB connects to.
    And GDB requests the thread information from them.
    In detail it is a bit more complex, but that's on another topic.
    Johannes
  • The new beta of JLinkGDBServer just got released with the support for Thread Awareness:
    Quote
    - GDBServer: Implemented support for thread debugging
    with RTOS by using a plug-in
    The manual says there is a plugin needed:
    Quote
    RTOS plug-ins for embOS and FreeRTOS are available from our website: https://www.segger.com/jlink-software.html.
    my problem: I cant't find the plugin on the stated website.
    where to get it ?
    thank you very much!
    Unfortunately, the manual is incorrect about this at the moment.
    The plugins are not available on the website, but will be included in the next version of the J-Link software,
    which is scheduled for release tomorrow evening or Monday.
  • I've installed the latest beta and my command line to load the FreeRTOS plugin. Are there any modifications for FreeRTOS that need to be made to enable support? I see in my console out that the dll was loaded properly, but when I pause execution, I only see the one thread.
  • Most probably the plugin does not find all the required symbols.
    There was a change in FreeRTOS, that eliminated a mandatory symbol.
    In this case, you should see something like this in your console:
    You can use the same patch as for OpenOCD to reintroduce the missing symbol:
    https://github.com/gnuarmeclipse/…eRTOS-openocd.c
  • could you please print what symbol the rtos plugin is missing?
    edit:
    I'm using the FreeRTOS plugin, but embOS symbols are requested:
    C
    Received symbol: OS_Global (00000000)
    ERROR: Received mandatory symbol not found.
    these are the parameters to run JLinkGDBServer:
    C
    ./JLinkGDBServer -if swd -device STM32F429VG -endian little -speed 1000 -port 2331 -swoport 2332 -telnetport 2333 -vd -ir -localhostonly 1 -strict -timeout 0 -nogui -rtos GDBServer/RTOSPlugin_FreeRTOS.so
    Edited once, last by pruesch (June 7, 2016 at 10:58 AM).
    it is the last received symbol "uxTopUsedPriority", return value NULL means it is not found.
    I already have changed the error message in the console to a more informative one.
    If your console output (starting with the first "Received symbol") is different, please post it here.
    Arne
  • Hi Arne,
    please see my edited post above
    strings like "pxCurrentTCB" and other symbols are not part of the RTOSPlugin_FreeRTOS.so but contained in the windows dll.
    maybe there is something missing :)
    Edited once, last by pruesch (June 7, 2016 at 11:16 AM).
    there was a problem within the build process causing both plug-ins to be identical in the linux and OSX builds.
    This will be fixed in the next release.
    I assume, you are using linux, right?
    Please find attached the correctly build plug-in.
    Arne
  • yes, we are using Linux (more specific CentOS 6.7)
    thank you very much for your super fast reply and the patched library! the plugin works now!
    I 'm back to the usual eclipse trouble when it comes to displaying the call stacks of various threads :(
    Edited once, last by pruesch (June 7, 2016 at 11:56 AM).
    good to hear that is working now.
    I have also experienced lots of trouble with building the call stack in eclipse while developing the plug-ins.
    Unfortunately there is nothing I can do, because this is completely done inside eclipse and the GDB server only sees some "read memory" instructions while eclipse is building the call stack.
    Arne
  • yes, eclipse, even the mars.2 release, is far from perfect.
    I noticed that the full call stacks appear again if you switch the perspective to c/c++ and back to debug.
    what issues did you experience? were you able to find workarounds for some of them?
    I'm really happy that you decided to implement thread awareness into your gdb server. It's also very nice that you support OSX and Linux! Your competitors don't seem to understand that need :)
    This confirms our conviction to have made the right decision to use segger tools now and in the future :thumbup:
    there were many different issues. Missing/empty lines in the call stack, registers disappeared from the registers pane up to complete crash of eclipse.
    You could try another IDE as a workaround, for example our own IDE Embedded Studio. It is available free of charge for non-profit educational purposes, supports Windows, Linux and Mac OSX and has an interface for viewing threads, too.
    Arne
    This worked! Thanks for the help!
