Hello.
I'm testing MEMDEV_AttitudeIndicator.c
I see only part of the image.
The problem starts in the _CreateScale function.
GUI_MEMDEV_CreateFixed returnes zero.
Can you please help me to achieve the handler.
Thank you.
STemWin528 + STM32F7-discovery, GUI_MEMDEV_CreateFixed
if GUI_MEMDEV_CreateFixed() returns with zero there is not enough memory available for the memory device. Please increase the size of the memory block assigned to emWin in GUI_X_Config().
Regards, Jörg
Hello, Jörg.
Thank you for the answer.
When I increase the memory to required minimum (#define GUI_NUMBYTES (1024) * 700) I receive the error (IAR EWARM):
unable to allocate space for sections/blocks with a total estimated minimum size of 0xafb74 bytes (max align 0x8) in <[0x20000000-0x2004ffff]> (total uncommitted space 0x50000).
The board has external SDRAM. Is it possible to include it for the task? I see that the part of the SDRAM is used:
#define LCD_LAYER0_FRAME_BUFFER ((int)0xC0200000)
#define LCD_LAYER1_FRAME_BUFFER ((int)0xC0400000)
RAM memory organization is a little bit messy for me... -
I have attached some files to show what is neccessary to give emWin more memory. Since I'm not how big the SDRAM is I disabled the second layer and used as GUI RAM.
GUI_Conf.c:
I just added a @ "GUI_RAM" behind aMemory[] to tell the linker where to put that array. In this case into section GUI_RAMLCDConf.c:
Of course, now it is not possible to enable the second layer because it would overwrite the GUI RAM.stm32f746xx_flash.icf:
I have defined a start and end address for a SDRAM region, defined the SDRAM region and placed the GUI_RAM section into SDRAM region.Now it should be possible to increase the memory up to 2MB
