Hello Everyone,
I have problem with J-Flash V5.10g and XMC4700.
When I try to erase the memory (erase sectors or erase chip), after a short time an error dialog is shown with message: "Timeout while erasing sector, core does not stop".
The Log is the following:
Connecting ...
- Target interface speed: 4000 kHz (Fixed)
- VTarget = 3.343V
- Initializing CPU core (Init sequence) ...
- Initialized successfully
- Connected successfully
Erasing selected sectors ...
- 10 of 10 sectors selected, 1 range, 0xC000000 - 0xC1FFFFF
- RAM tested O.K.
- Erasing bank 0, sectors 0
- ERROR: Timeout while erasing sector, core does not stop
- ERROR: Failed to erase sectors
Disconnecting ...
- Disconnected
Settings are:
Target interface: SWD, speed before init 4000kHz, speed after init 4000kHz
CPU: Infineon XMC4700-2048
All other settings are the default.
In the same board, with XMC4500 I never had problems.
Any suggestion?
Thank you.
