How to implement Long press and double tap on a button ?
    The parent window of the buttons window receives notification codes WM_NOTIFICATION_CLICKED and WM_NOTIFICATION_RELEASED from the buttons. To implement long press a timer could be used. If it is expired and no release has been detected in the meantime a long press occurs, if a button is pressed twice within a short period a double tap is detected.
    Regards, Jörg
  • Hi Jörg,
    Thanks for your reply. Yes, i was thinking the same logic. I was just curious if there is any special implementation for this event, but looks like there is not. Thank you so much :)
