how to create xbf font? Have to use fontCvt? I didn't found the option to "export/create" xbf file from font..
Thx
Thx
Yes, the Font Converter can be used to create XBF files. You can just choose "File" -> "Save As..." and select the XBF format.
Adrian
Adrian
thx adrian!
But is it possibile only for "not anti aliased" font? If i use the same font antialiased i can't see "Xbf format"
The current version of the Font Converter can store all types of fonts as XBF. Could you please tell me which version you use? Thank you.
Adrian
Adrian
Hello Adrian!
I use font converter 5.22. If i use "New" to create a font and i choose "Antialiesed, 2/4 bpp" i don't have the possibility to create an xbf file
You are right. I thought you tried using extended fonts. Standard antialiased fonts indeed can not be stored in the XBF.
Please note that it is generally recommended to use Extended fonts.
Adrian
