Dear Adrian,
Hello. I am having some problems driving LCD modules using emWin. The program gives a hard fault on LCD_SetPosEx(0, 0, 0) in LCD_Config.c. I know the problem is most likely caused by hardware, but I do not know where to start testing. Would you please tell me what happens inside that function so that I know where to look for the problem?
Hard fault on LCD_SetPosEx(0, 0, 0)
This function should be documented. So first of all thank you for the hint. We will add a description of this function to the emWin user manual.
Prototype:
int LCD_SetPosEx(int LayerIndex, int xPos, int yPos);Description:
Sets the position of the given layer.Return value:
0 if the command was successfully processed; 1 if the command was not processed.Additional information:
This function should be called only in case multiple layers have been configured.Best regards,
Adrian -
Dear Adrian,
Thanks for your updates.
As I mentioned in my previous post, all the code before LCD_SetPosEx(0, 0, 0) is executed just fine, but the program does not return from this function and gives me a hard fault. I was wondering if you could tell me what functionality happens inside this function. What could be the hardware problem with LCD? I mean where this function is prone to hard faults.
Best regards -
The function LCD_SetPosEx() should be used only in a MultiLayer environment. This function expects an emWin display driver to be configured which supports the display driver command LCD_X_SETPOS. The hard fault therefor may be caused by a NULL pointer.
As far as I know usage of multiple layers are supported by GUIDRV_Lin, only. So if you do not use this driver, you should not be calling the function LCD_SetPosEx() at all. We will make this clear in the emWin user manual to avoid future misunderstandings.
Adrian
