Hi folks,
I'm using Bitmap Converter (BmpCvtST.exe, v5.26, STemWin package) to convert images for display. Ordinarily when I save I select the "High color [565] compressed" output format and all is well. At the moment I am working with an image that has an Alpha channel and transparent portions. When I 'Save As' that option does not come up. The closest is "High color with Alpha [565]" but that doesn't work well. The image is a red X (255,0 0) and it appears black (but the transparency part works.)
The option that provides the visual results I like (Red X, background otherwise visible ) is when I save with the option "True color with alpha channel" but it uses gobs of flash since it is not compressed. I have tried "True color with alpha channel, compressed" and nothing appears when the code issues the call to draw the image.
Is there any to draw a compressed image with transparency on the LCD? The LCD is configured for 16 bit (565) color.
Code that draws the image looks like:
case ID_BUTTON_1: // Notifications sent by 'Submit'
switch(NCode) {
case WM_NOTIFICATION_CLICKED:
// USER START (Optionally insert code for reacting on notification message)
hItem = WM_GetDialogItem(pMsg->hWin, ID_IMAGE_2);
IMAGE_SetBitmap(hItem, &bmRedX);
// USER END
break;
case WM_NOTIFICATION_RELEASED:
IMAGE_SetBitmap(hItem, &bmclear);
// USER END
break;
// USER START (Optionally insert additional code for further notification handling)
// USER END
break;
bmRedX is the image with transparency and bmclear is a 1x1 pixel transparent image. The red X is painted when the button is touched and removed when the button is released. (That party works brilliantly assuming the button actually appears. )
Thanks!
(Uh, sorry. The forum S/W has hopelessly mangled the code if I use the 'code' tags. It looks better if I just copy and paste?)
