Hi folks,
I am using a dialog (Window rooted with various widgets rooted in a Framewin) as a popup and want the dialog to be modal. However when I do this, the widgets in the modal dialog do not receive WM_NOTIFICATION_RELEASED events. This is awkward as some of them cannot then be pressed twice since they remain 'pressed' until another widget is touched.
I can work around this by not making the popup modal and instead disabling widgets in the parent dialog but this requires more code and logic than the single "WM_MakeModal()" call.
Is there a way to get WM_NOTIFICATION_RELEASED messages in a modal dialog?
Thanks!
