After reverted my windows with a clonezilla image I had to install em:block 2.30 and segger j-link sw version 4.96g. I also then got firmware of my jlonk edu upgraded. However, when I now tries to start my project for debug, which before i reinstalled the windows image worked perfectly every time, em:blocks recompiles as expected but the debugger gdb server is not started.
I have tried to get some info on em:blocks forum but until now I have not got any replies.
Thing is, I had em:blocks 1.45 installed in my old windows image and when debugger is started here the gdb server is launched aswell. But not when running from em:blocks 2.30.
I just wondered if anyone have had any experience with this and found a solution.
Yes I have followed the guide found under supported IDE's at segger.com but to no help.
I may start the gdb server manually and it connects to my jlink debugger and waits for connection, but nothing happens when I try to start a debugg session form em:blocks.
Thanks in advance
You may find my post at em:blocks forum here:
http://www.emblocks.org/forum/viewtopic.php?f=19&t=566
Breg
Vidar
