Debugging and flashing fails with CodeSourcery
  • I am trying to flash an debug an STM32F205 MCU using J-link and Codesourcery 2012.09-85.
    I have tried several version of J-link software, including the latest one (4.66).
    The JFlasher can read and flash the MCU just fine, but flashing and debugging does not work from CodeSourcery.
    I keep getting error messages:
    -target-download C:/src/sandbox/Ruck/Lisa/MCU/D322_00/Lisa_Debug_HP/D336_00
    Error message from debugger back end:
    Error erasing flash with vFlashErase packet
    Also the debugger seems to be unable to read back data from ROM or RAM.
    This is the same with a STM3220G evel board and our own boards.
    I don't think it is a hardware problem as most of the boards have been successfully debugged before using an older version of CodeSourery.
    Any ideas?
  • This sounds as if Codesourcery had changed their GDB interface.
    Normally, the vErase packet should not be sent (It should only be sent if the GDBServer reports that it can handle this packet).
    Since J-Link handles Erase automatically, there is no need to handle this packet, and it should not be sent.
    In any case, we will look into this and either modify the J-Link GDBServer or get in touch with CodeSourcery (Mentor) asking them
    to fix it, assuming that we can reproduce it.
    Until then, it seems an easy workaround is to use an older version of CodeSourcery, especially as you write
    that an older version of this stuff works:
    Quote
    Which older version are you using that works and can you verify it also works with the STM32F205?
    J-Link can handle that device.
    Could you please share some more information about how you use J-Link from within CodeSourcery?
    Do you use it directly (by selecting J-Link in CodeSourcery)?
    Or do you select "GDB" as debugging interface and explicitly start J-Link GDBServer and let CodeSourcery connect to it?
    I assume that you use J-Link directly. If this is the case, there is not much we can fix here since CodeSourcery communicates
    with the J-Link DLL directly and performs some CodeSourcery-internal GDB <-> J-Link mapping, so we do not even get this "vFlashErase" packet.
  • Hi Alex,
    thanks for your reply.
    The version that had worked previously was: 2011.09-82
    I tested it successfully with an STM32F207 (did not have a 'F205 at the time), after updating the DLL to version 4.56d, as the version included in codesourcery (4.42b) did not support the 'F207.
    You assume correctly that we are using J-ling directly from within CodeSourcery.
    I have received a modified version of the Debug sprite, but it did not fix the problem. A attach a debug log file, maybe you can find something there.
    The log window of the JLink interface seems to show no problem. Is there a way to save an attach that log, too?
    Bernhard
  • Hi Bernhard,
    Quote
    As far as I understand it, it looks good.
    I do not even see any errors regarding "vFlashErase" being reported there.
    Quote
    Could you please specify what you mean here?
    In general, a J-Link log file can be created by opening the control panel (just click the small J-Link tray icon in the bottom right corner which shows up as soon as the debug session is started)
    and select "Override" for the logfile in the "Settings" tab.
    Then just re-start the debug session to get a complete log from the beginning.
  • Alex,
    I have tried some more here. I found the using the "STM32F207IG" as an MCU type in the board file (code sourcery), flashing does indeed work fine. Changing the chip to "STM32F204ZF" (which is actually used on our board), flashing no longer works. Both chips are set to use 768k of flash.
    This is the version info from the GDB server:
    EGGER J-Link GDB Server V4.56d
    JLinkARM.dll V4.56d (DLL compiled Nov 12 2012 20:40:34)
    Next problem after flashing is this:
    I can see the program start at the beginning of "main()" function. I can also step over other functions called by main().
    However when I set a breakpoint and run the application, it does not correctly stop at the breakpoint as expected.
    Instead the IDE shows an incomplete stack trace:
    Thread [1] <main> (Suspended : Signal : SIGTRAP:Trace/breakpoint trap)
    0x0
    0x0
    Also there is an error message about being unable to registers while the MCU is running (which is probably the cause for the invalid stack)
    I attach the log window output of the segger GDB server. Maybe you can see something from it?
